wiring amp and sub
jojo1212
Member - Posts: 13
Posted: May 02, 2011 at 4:23 PM / IP Logged
hi all
recently i got my hands on a rockford p600.1bd amp and a cerwin vega stroker 12" d2 sub
the amp specs as below
Number of Channels      1
(RMS Continuous Power)      325 Watts x 1 @ 4-Ohms
600 Watts x 1 @ 2-Ohms
Total Power
(Sum of Rated Power)      600 Watts
Not Bridgeable
the sub specs as below (but Im not sure about the specs, coz i found them on the net and couldnt find a certified cerwin vega manual or specs for this sub)
1000 WATTS RMS. 500 WRMS PER VOICE COIL
DUAL VOICE COIL, IMPEDANCE 2 OHMS PER VOICE COIL
all are hooked up and ready, i just need to know how to wire this sub to my amp and get the most out of both of them
thanks
ac0j
Copper - Posts: 121
Posted: May 02, 2011 at 8:33 PM / IP Logged
If this is a dual 2 ohm sub, and your amp is only stable to 2 ohms, You can either series the voice coils to run 4 ohms at the amp, or just hook up one voice coil to run 2 ohms.
jojo1212
Member - Posts: 13
Posted: May 03, 2011 at 9:19 AM / IP Logged
thanx for the reply
my question is :
-if i run the voice coils in series i will get 4ohm
and my AMP will only supply 325watts rms to the sub, right ??
-if i run only 1 voice coil from the sub to the amp
it will be 2ohm load so my amp will be suplyin 600watts rms
if this is right, so running one voice coil at 2ohm would be
better coz im feedin it more power, but will 1 voice coil
be able to take those 600watts rms since 1 voice coil is only
500rms ??
thanks
ac0j
Copper - Posts: 121
Posted: May 03, 2011 at 10:13 AM / IP Logged
Yes one voice coil gets the most power, If you do not distort it and set the gains properly you should be fine.  If the voice coil goes bad, use the other one!
jojo1212
Member - Posts: 13
Posted: May 03, 2011 at 10:44 AM / IP Logged
i see
thanx alot :)
blanx218
Silver - Posts: 654
Posted: May 04, 2011 at 11:45 PM / IP Logged
Its never good to set the gain on your amp to max volume. Your power ratings are also RMS not peak so using the amp at around 3/4 gain should keep the amp, sub, and ears all happy
