changing of activation pulses
matthew210
Posted: June 08, 2011 at 12:41 PM / IP Logged
My friend and I both recently installed Viper 5901's in our trucks.  We each changed the programming to require 2 activation pulses for a remote start.  It works on the activation wire, but they will no longer start with our remotes.  I'm guessing we have to update the remote to match the 2 count, but I didn't see it in the manual.  I'm sure I'm just overlooking an easy answer.  Anyone have the answer?
Matt
mikvot
Gold - Posts: 1,043
Posted: June 08, 2011 at 12:51 PM / IP Logged
If i remember right, when you change that setting it also changes it for the transmitter. You will have to push the remote start button twice.
matthew210
Posted: June 08, 2011 at 1:42 PM / IP Logged
The manual says that it changes it for the wire, and for the remote.  When I click the remote start button the first time, it automatically tries to send the command to the car.  So even if I press it twice quickly, it starts to send the command after the 1st press, and still fails.  Maybe I have to re-pair the remote to the car?
Matt
buddholly
Copper - Posts: 244
Posted: June 08, 2011 at 1:55 PM / IP Logged
Yup. You need to hit remote start button twice. Press once...wait one sec...press again.
Posted: June 08, 2011 at 2:36 PM / IP Logged
buddholly is quite right, learn to leave a 1/2 second gap between pressing, oh and by the way it will drive you mad, you'll soon change it back.
KPierson
Platinum - Posts: 3,527
Posted: June 08, 2011 at 2:50 PM / IP Logged
With my Clifford 50.5x I have found that the easiest way to start my truck with the activation set to "2" is to either climb a ladder or kneel down. Simply pressing the button twice, leaving any amount of reasonable time, doesn't seem to reliably start the vehicle. However, EVERY time I bend my leg in an awkward way within range of the truck it will start every time.
Kevin Pierson
Posted: June 08, 2011 at 5:03 PM / IP Logged
There you see; I told you so, Mr. P. has already been driven round the bend.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
