relay for rear fog lamp
jukkaep3
Posted: June 08, 2011 at 1:57 PM / IP Logged
I'm trying to wire up a rear foglight in my civic and I've run into a bit of a snag. I bought an OEM combination switch off a type-r from a guy in the UK in hopes it would work. The problem being is that the switch on the combination switch for the rear fog is a momentary switch. Now ive looked through some of the diagrams people have listed showing circuits for momentary to constant, but they always show an dual outputs, I only need a single.
So pretty much what im looking for is an answer on how to wire up the momentary to a single point with a basic on off feature.
I've tried looking for/at the wiring diagram for a UKDM civic, but I couldnt figure out how they had converted the momentary to a constant.
Platinum - Posts: 13,725
Posted: June 08, 2011 at 7:11 PM / IP Logged
oldspark
Gold - Posts: 4,913
Posted: June 09, 2011 at 3:35 AM / IP Logged
See also Latched on/off momentary w/ brake kill.
I use one ordinary SPST relay as latching relay, but you need to break the power (or coil +12V or gnd) for it to un-latch.
Posted: June 10, 2011 at 4:29 AM / IP Logged
Does this momentary switch give a pos or neg output?
