1996 f 150 accessory wire for a/c
06f150
Copper - Posts: 57
Posted: June 19, 2011 at 5:27 PM / IP Logged
1996 Ford F-150 5.0
Have an ultra stater installed and everything works great besides one thing.
When under remote starting the A/C does not run, the fan blows but the compressor is not engaged. As soon as you put the key in and turn it over, it then turns on and runs like it should.
I am looking at the wiring diagram and it has gray / YELLOW for the accessory and blue/green for heat and A/C...
Thing is the heat works just fine under remote starting, its just the A/C that is not engaging. And with what the wiring diagram is telling me is that they use the same wire, so if heat works the A/C should too...
I'm going to look at it in a day here to verify all wires but I am not sure if I am missing something...or if someone else has different diagram with another wire color listed?
Thanks guys!
Platinum - Posts: 13,726
Posted: June 19, 2011 at 6:04 PM / IP Logged
Did you power both of the ignition wires listed below?
1996 f 150 accessory wire for a/c - Last Post -- posted image. Battery YELLOW (+) IGNITION SWITCH HARNESS
1996 f 150 accessory wire for a/c - Last Post -- posted image. Ignition 1 RED / LIGHT GREEN (+) IGNITION SWITCH HARNESS
1996 f 150 accessory wire for a/c - Last Post -- posted image. Ignition 2 GRAY / YELLOW (+) IGNITION SWITCH HARNESS
1996 f 150 accessory wire for a/c - Last Post -- posted image. Accessory 1 GRAY / YELLOW (+) AND BLK/GRN IGN SW HAR "BLK/GRN FOR AC"
1996 f 150 accessory wire for a/c - Last Post -- posted image. Starter 1 RED / LIGHT BLUE (+) IGNITION SWITCH HARNESS
The heat does not need to power the AC compressor.  The statement "If the heat works, the AC should too" is not true.
06f150
Copper - Posts: 57
Posted: June 21, 2011 at 2:44 PM / IP Logged
Ah, Learn something everyday.....I went out testing wires and it was the GREEN/ back wire for the A/C that I had missed to hook up. Now everything is running like it should!
Thanks for the help!
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
