which relay for type b door locks
eddiejb11
Posted: August 02, 2011 at 12:45 PM / IP Logged
I was installing an alarm on a f250 2006 type b and I encountered a problem with the door locks, I connected all the wires, alarm activates/disactivates but it won't lock, unlock, after some reading and researching I found out I needed relays on my locks because of polarity, anyone knows which relay I need and how to instal, where to pick some up??? Thx
Want things done, get it done yourself
Platinum - Posts: 7,828
Posted: August 02, 2011 at 4:11 PM / IP Logged
Did the truck come with Factory Keyless Entry?
eddiejb11
Posted: August 02, 2011 at 6:23 PM / IP Logged
No, type b non keyless entry, I was looking at the wiring and it had an alarm before, in the driver kick panel it has it original wires cut by 2 inches so it had a gap in the door lock switch wires and they connected it together as it had something missing, which I assume it had a relay, I saw this and I figure it's what I need, http://www......com/item_8487_Directed-451M.html
eddiejb11
Posted: August 02, 2011 at 8:36 PM / IP Logged
Sry, type c
Posted: August 02, 2011 at 9:30 PM / IP Logged
Sounds like you have Type C ( rev) locks.
Here is info from Bulldog Security for the 2006 Super Duty with Factory power locks:
NOTE #3: Vehicles WITHOUT a FACTORY KEYLESS Entry Remote Control are a TYPE "C" Door
 Locking System. Vehicles WITH a FACTORY KEYLESS Entry Remote Control are a
 TYPE "B" Door Locking System and the LOCK wire is a WHITE/ RED (TYPE B) and the
 UNLOCK is a BLACK/ WHITE TYPE B), BOTH are located in the Drivers Kick Panel, at the
 Door Harness.
If your truck has factory power locks without remote keyless entry FOB's, you have
Type C locks ( rev ) and the DEI 451M module will handle it.  Here is a link to the
DEI 451M install guide :  https://www.the12volt.com/installbay/file.asp?ID=726
Don't know which Brand / Model alarm system you are installing, but some do have built
in relays, in which case the 451M isn't needed.
Posted: August 03, 2011 at 1:02 AM / IP Logged
Does your alarm have two lock wires or six?
eddiejb11
Posted: August 03, 2011 at 4:08 AM / IP Logged
2
Posted: August 03, 2011 at 4:39 AM / IP Logged
Then take Kreg's advice and use a 451 module, it comes with instructions.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
