2011 toyota highlander immobilizer
Johnnynguyen20
Copper - Posts: 89
Posted: September 18, 2011 at 11:15 AM / IP Logged
hello, i'm on the process of installing a Viper 5901 with Expresskit DB-ALL module firmware 401.TL4 v1.08. On the 2011 TOYOTA HIGHLANDER 4 CYLINDER
i have problem finding the IMI/IMO immobilizer wires. The installation of the db-all module show that 2011 Toyota Highlander 4 CYL IMI wire is Blue 31 pin, and IMO wire is Violet 32 pin, at At ECM, behind glove box, white 36-pin
(2nd from top), conn. D60
as i look at the 2nd plug from the top of the ECM the 31 pin is Blue and 32 pin also blue. can someone please help.
Johnnynguyen
Platinum - Posts: 7,828
Posted: September 18, 2011 at 12:53 PM / IP Logged
Here is a link to the Fortin EVO-ALL Install Guide for the 2011 Highlander :  https://ifar.ca/en/download/2919/preview.html  They list the wires as Light Blue and Violet at those locations and include a diagram of the connector.  Also verify your key has a "G" stamped on it for 80 bit encryption.
Johnnynguyen20
Copper - Posts: 89
Posted: September 18, 2011 at 1:37 PM / IP Logged
this 2011 Toyota Highlander Keys does not have the "G" stamped on, and doesn't have the Dot stamped on it either. The DB-ALL module does show the IMI, IMO connector and pin layout, i'm sure that i got the connector right, i have recheck and look for it 100 of time, still don't know with pin its go, there is like 2 violet wires, and few light blue wires on the connector.
Johnnynguyen
Mike M2
Platinum - Posts: 2,652
Posted: September 19, 2011 at 6:23 AM / IP Logged
If it's not an SE model it doesn't have an immobilizer at all. Look for a transponder ring around the ignition key....
Mike M2
Tech Manager
CS Dealer Services
chrisf88
Posted: September 20, 2011 at 4:04 PM / IP Logged
If it doesn't have the G stamped on it, it's a 40bit key. You do not need IMI and IMO wires, but RX and TX wires near the ignition switch.
Radio d'Auto Mobile Inc. Installer
Québec, Qc, Canada
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
