viper alarm /remote start
mbalenhle
Member - Posts: 6
Posted: October 17, 2011 at 8:26 PM / IP Logged
HI.
I need help please, i have car alarm python 323 model (viper 3202) , and a car remote start python model 1401(viper 5101) all connected to a chevy cruze, 2011 model , my problem is i can not get them to work together ,i have a problem with bypassing the python alarm system when its armed,when i remote start the car the alarm goes off, i have tried connecting the status output wire from the remote start to the H1/7  blue wire main harness 12 pin connector of the alarm system as they suggest in order to bypass some alarm zones but no luck, the alarm sysem is connected thru  a D-ball all bypass system which strangely have taken over the vehicle antitheft system i can arm and disarm the factory system with python remote .
Any suggestions will do thanks.
mba222
smokeman1
Platinum - Posts: 1,589
Posted: October 17, 2011 at 9:03 PM / IP Logged
Mine thought would be take them out and put in a Python 872, (Viper 5701).
KPierson
Platinum - Posts: 3,527
Posted: October 18, 2011 at 2:59 PM / IP Logged
What is triggering the alarm? Is it the ignition input, the door pin, the trunk pin, or the shock sensor (or another sensor installed)?
I would guess it's the ignition signal - if it is you may need to diode isolate that signal from the remote start output so that the alarm never sees the ignition voltage provided by the remote start.
Kevin Pierson
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
