dodge ram 1500, driving and fog lights
jbjceg
Posted: November 25, 2011 at 9:35 AM / IP Logged
I am installing auxiliiary driving and fog lights, a total of 400 watts,  to a Dodge Ram 1500 4wd pck up.  My wondering is about whether the stock electrical sysytem will handle the extra load.  I don't mind adding an auxiliary battery through an isolator, but I do wonder if an isolator is the way to go?  Any ideas?
performance713
Member - Posts: 19
Posted: November 26, 2011 at 2:13 PM / IP Logged
i don't think you need a isolator but it will work also, i would just wire up a relay system and use the factory electrical fog light signal for the relay. You can use any 12v relay, you can wire up pin 30(+) to aftermarket fog lights, pin 86(-) ground, pin 87(+) to battery power recommended fuse 35amp max,and pin 85(+) from factory fog light signal.
You can also use two relays if you would like, depends how many fog lights you are running.
im ( J ) and car audio is my thang.. and if i can help i will.
