dei vs compustar d2d connection
dman007
Copper - Posts: 106
Posted: December 27, 2011 at 11:35 AM / IP Logged
Are Compustar systems D2D connections compatible with DEI Startsmart D2D connections.
I want to hook up a Compustar 600-S(remote starter) to a dsm200(smart start add-On) using the D2D connection for ease of installation. Would this be possible?
DTS Performance
St Petersburg, FL
armbruster
Member - Posts: 32
Posted: December 27, 2011 at 6:13 PM / IP Logged
This DSM200 is compatible with all Directed Electronics Security, Remote Start and hybrid systems that are Bitwriter™ (3 or 4 pin) compatible. I do not think it will work w/the data port of a Compustar System.
dman007
Copper - Posts: 106
Posted: December 27, 2011 at 6:30 PM / IP Logged
You are correct I confirmed today that Dei and compustar D2D connections are not compatible. So any Dei system has to be w2w with fortin and idatalink bypasses.
DTS Performance
St Petersburg, FL
Platinum - Posts: 7,828
Posted: December 27, 2011 at 6:51 PM / IP Logged
Unless you flash the iDatalink bypass module with the DBI firmware ( instead of the ADS firmware ).  Example ADS AL(DL) CH4 firmware on the ADS AL-CA bypass for a CS600-S remote starter vs DBI AL(DL) CH4 for a Viper 5701 unit.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
