python 1401 viper 5101 trouble
thebigdogrocks
Posted: December 29, 2011 at 7:51 PM / IP Logged
I am installing the python 1401 with PKALL bypass modular on a 2002 ford escape and I have a couple of question that Im needing help with
Door Lock, 3 Pin Connector
The door lock/unlock on the escape is a single wire (pink/white) that operates both the lock/unlock. I have connected both the blue (unlock) and the green (lock with 1k resestor) to the single (pink/white) wire as the direction said. The unlock works but not the lock. What did I do wrong?
Remote Start, (H3) 8 Pin Connector
My question is about the gage of the wire on the Escape. I am not finding any wires that are the same gage (on the escape 14/16 gage) for H3/4, 5, 8. Am I able to tie into such small wires? Am correct that the "flex relay" lines I don't need to hook up?
Thanks for input and help. This one is killing me
ropuma
Copper - Posts: 102
Posted: December 29, 2011 at 9:40 PM / IP Logged
you need two relays for lock and unlock to work
ropuma
Copper - Posts: 102
Posted: December 29, 2011 at 9:43 PM / IP Logged
12 VOLT CONSTANT   Connect to BATTERY ONLY   @ IGNITION SWITCH HARNESS
 STARTER  TAN/LIGHT BLUE (+)  @ IGNITION SWITCH HARNESS
 STARTER 2  N/A
 IGNITION 1  LIGHT GREEN/ PURPLE (+)  @ IGNITION SWITCH HARNESS
 IGNITION 2  N/A
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  BLACK/ LIGHT GREEN (+)  @ IGNITION SWITCH HARNESS
Use this wires for remote starter
thebigdogrocks
Posted: December 30, 2011 at 11:46 AM / IP Logged
Thanks for the information about the relays. I found the link concerning how to install them on this site as well. Also thanks for the wires codes and locations .
I still trying to make sure that I can concect the larger gage start wire from the remote starter to an small gage wire (Tan/Light Blue) under the dash in the ignition switch harness. OR am I just not finding the correct wire to correct wire (Tan/Light Blue) under the dash.
Thanks!
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
