Directed 530t for 2006 Hummer H2
bwhummer
Member - Posts: 7
Posted: January 04, 2012 at 11:22 AM / IP Logged
Howie II,
I found a single cable with four 12 gauge wires inside today at a hardware store and I was wondering would this be useful in this setup for the 530t's? I want to not have
a bunch of individual wires scattered or tape rapped. Oh - and I'm making that call to the installer in Atlanta that gave me the bad information.
Posted: January 04, 2012 at 11:34 AM / IP Logged
Should be.
Posted: January 04, 2012 at 5:42 PM / IP Logged
Of course you were with that name, the old folks?   Directed 530t for 2006 Hummer H2 - Page 2 - Last Post -- posted image.
France, beautiful country, beautiful food, awful people and cars.
Except in Provence, probably the Italian influence.
I must be getting really senile, I can't find the last Metz post for which this is the reply!
bwhummer
Member - Posts: 7
Posted: January 05, 2012 at 5:02 AM / IP Logged
Directed 530t for 2006 Hummer H2 - Page 2 - Last Post -- posted image.Howie II,
Man.....so called to tell the fella in Atlanta a thing or two about the instructions he gave me and he still swears by the details he provided for the installation of the two 530t's for the 06' Hummer H2. He even double checked and looked it up again on "Direct Wire". He said is it is 100% possible to tap directly into the driver door window control module with both 530t's and achive positive results.
I then go and call the car audio dealer where I recently purchased all my High-End Audison equipment and he siad basically the same thing. He also provided a Direct Wire Vehicle information datashee for the 2006 Hummer H2 seen below.
Now i'm frickin' afraid to go in there and jack something up!
DirectWire Vehicle Information - 1/4/2012 12:37:44 PM
Copyright © 2011 Directed Electronics. All Rights Reserved. DirectWire and its vehicle information are for
the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The
information contained on these pages may contain confidential and privileged information. Any unauthorized
review, use, disclosure or distribution is prohibited.
Right Front Heated Seat
Left Front Heated Seat
Mirror Defroster
Rear Defroster
Fuel Pump
Clutch Pedal
Neutral Safety
Wait to Start N/A
Tachometer white ac PCM, green plug, pin 10
Trunk Alarm Shunt
Disarm No Unlock see factory alarm disarm
Factory Alarm Disarm lt. green - driver door module in door
Factory Alarm Arm arms on lock
Power Sliding Door (Right)
Power Sliding Door (Left) N/A
Fuel Door Release
Trunk Release Motor
Trunk Hatch/Release N/A
Hood Pin N/A
Rear Glass Pin
Trunk/Hatch Pin pink/black - BCM, purple plug, pin A1
Dome Supervision gray/black + BCM, black plug, pin E
Right Rear Door Trigger
Left Rear Door Trigger
Right Front Door Trigger
Left Front Door Trigger see notes - see notes
Reverse Light lt. green + BCM, black plug, pin F
AutoLights
Headlight white - BCM, lt. blue plug, pin A12
Item Wire Color Polarity Wire Location
Wiring Information (Continued)
Satellite Audio Right (+/-)
Satellite Audio Left (+/-)
Satellite Radio Antenna
Satellite Radio Ignition
Satellite Radio Ground
Satellite Radio 12 Volts
RSE Audio Right (+/-)
RSE Audio Left (+/-)
RSE Video (+/-)
Aux. Audio Input Right (+/-)
Aux. Audio Input Left (+/-)
Subwoofer (+/-)
Center Channel (+/-)
Right Rear Speaker (+/-) dk. blue - lt. blue +,- amp under center console
Left Rear Speaker (+/-) brown - yellow +,- amp under center console
Right Front Speaker (+/-) lt. green - dk. green +,- amp under center console
Left Front Speaker (+/-) tan - gray +,- amp under center console
Power Antenna gray (some models) + radio harness
Factory Amp Turn-on pink (some models) + radio harness
Radio Illumination N/A
Radio Ignition (Class 2 Serial Data)
Radio Ground BLACK/ white - radio harness
Radio 12V orange + radio harness
Memory Seat 3 N/A
Memory Seat 2 pink + driver door module in door
Memory Seat 1 red + driver door module in door
Sun Roof (Limit/Close) N/A
Sun Roof (Open/Close) motor part of module
Right Rear Window (Up/Down) dk. blue - brown C RR window switch in door
Left Rear Window (Up/Down) dk. blue - brown C LR window switch in door
Right Front Window (Up/Down) dk. blue - brown C RF window switch in door
Left Front Window (Up/Down) dk. blue - brown C LF window switch in door
Wipers pink (L), dk. blue/white (H) - windshield wiper switch
Horn Trigger BLACK / YELLOW to black - switch or BCM, gray plug, pin B9
Parking Brake lt. blue - BCM, lt. blue plug, pin A7
Brake Wire white + brake pedal switch
Speed Sense dk. GREEN / WHITE ac PCM, green plug, pin 50
Satellite Radio Tuner
Right Rear Headrest
Left Right Headrest
Right Front Headrest
Left Front Headrest
Subwoofer
Center Channel
Right Rear Tweeter
Right Rear Speaker
Left Rear Tweeter
Left Rear Speaker
Right Front Tweeter
Right Front Speaker
Left Front Tweeter
Left Front Speaker
Headunit
Item Size Depth Location
What Fits
Copyright
Posted: January 05, 2012 at 5:42 AM / IP Logged
His info is OK if you don't need one-shot at the satellite switches. If you don't then wire it their way, if you do mine. The instruction manual says this as well, it's entirely up to you.
You could pick up the other three windows in the driver kickwell, you still have to go into the driver's door though.
Sunday, January 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
