2002 nissan frontier
rlowe75
Member - Posts: 24
Posted: January 12, 2012 at 11:09 AM / IP Logged
It's been awhile since I have installed a remote start. I got out of the business about 5 years ago. Anyways I ordered a Python 4102 and was looking through the wiring diagram and to be honest with you not for sure of some of the connections. Anyways the install guide talks about "Flex Relays". Any idea what these are? Also H1/10 WHITE/ BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT This input comes from the factory set to 1 activation pulse. This means that it is necessary to have a single ground pulse on the WHITE/ blue wire for the remote start to activate or to deactivate Should this be grounded or is this just another signal for the remote start via momentery switch?
Thanks for the help!!
It's all fun and games till someone looses an eye.
tedmond
Gold - Posts: 4,610
Posted: January 12, 2012 at 11:36 AM / IP Logged
flex relay is for an addition acc,ign or start of your choice if you need it. in this case all nissans will have a second start wire.
the WHITE/ blue is optional if you were to connect it a switch, or activation through factory remotes by tapping onto the door lock wire. pretty much what you suspected it to be, just another signal to activate start. DO not ground this wire.
Ted
Compustar Expert
sparkyssb
Copper - Posts: 205
Posted: January 12, 2012 at 11:37 AM / IP Logged
Pretty sure the flex relays are relays built into the unit so you don't have to provide them yourself. (such as parking lamp control) The H1/10 WHITE/ BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT can be left disconnected. Do not ground it. This is to turn on the remote start via a single pulse (ex, using a factory remote with an aux channel) or to activate the turbo timer.
rlowe75
Member - Posts: 24
Posted: January 12, 2012 at 11:42 AM / IP Logged
Since this truck as 2nd ignition do I need to relay it?
tedmond
Gold - Posts: 4,610
Posted: January 12, 2012 at 12:18 PM / IP Logged
from the looks of this vehicle, it only has a second starter wire. only one acc and ignition.
make sure you program that flex relay output for start.
easy vehicle to do.
Ted
Compustar Expert
Sunday, January 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
