Compustar Brain Update, Benefits Ford/Mazda - FYI
tedmond
Gold - Posts: 4,610
Posted: February 02, 2012 at 12:10 PM / IP Logged
When updating the compustar brain to:
CM5/6X00 With V6.7 VD6
when connecting to the BLADE through web-link 5, under options setting 1-12 you can change the door trigger to NC or NO. This is beneficial for those that install on older ford/mazda often. luckily late models we have the blade-al to take care of triggers for us. No need for resistors/diodes. leave the jumper on negative and diode isolate all 4 triggers.
not sure if a few of you were aware, but I just noticed this today. Usually i use my op500 to change settings after the install.
Ted
Compustar Expert
