2002 vw jetta r/s advice wanted
mchorvathm
Member - Posts: 9
Posted: July 12, 2012 at 9:01 PM / IP Logged
I'm wondering if the blade can even take care of the transceiver module via data, could be much more efficient install this way and require minimal hard wired attachments.
Posted: July 13, 2012 at 12:32 AM / IP Logged
The first diagram, saves a relay. I know nothing about connecting it to the blade unless the blade lists those functions on a 2002 which I doubt.
The usual pro rule on any install is to run W2W, it's more reliable.
mchorvathm
Member - Posts: 9
Posted: July 13, 2012 at 9:13 PM / IP Logged
since I cant post pictures Ill just type this up.
VW jetta 2002, blade AL, wiring type 1 (includes wires to loop key and iginition barrel for bypass) I just dont like the way its not boxed up
Jetta 02-05 1 • • • • • • • • •
AL Module will be functional on these vehicles only if they are equipped with electric windows.
features = priority unlock, door lock, door unlock, arm oem alarm, disarm oem alarm, door stat output, hood stat output, trunk stat output, tachometer output.
I think I'm going to wire this blade up on a 2 way compustar and use the 556uw to bypass the key. I'm still figuring out how this setup would apply to -
FOR REMOTE START: The vehicle can be remote started without disarming the factory alarm by using a relay to open the BLACK/ BLUE wire (ignition sense) at the steering column during remote start. You will also have to run your remote starter's start output directly to the starter relay RED / BLACK on the back of the fusepanel to bypass the factory starter kill.
I imagine if the blade can disarm the oem alarm I wont need to do this.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
