on off on switch wiring
badstr
Posted: July 26, 2012 at 4:50 PM / IP Logged
i have a dpdt switch that i need to wire position 1 is on postion 2 (center) is off and position 3 is on with postion 1 also on, i need wiring for all 8 postion thanks
badstr
Platinum - Posts: 13,725
Posted: July 26, 2012 at 9:19 PM / IP Logged
What kind of switch is it that has 8 positions? How much current will be going through the switch? Is it switching power or ground?
badstr
Posted: July 26, 2012 at 9:31 PM / IP Logged
its a waytech# 44326 switch , it only has to send a signal to the relays for the hot side,  what its for is a fan and water pump  in one position i want to turn on the fan and in the other both but i dont know how to wire it
badstr
Posted: July 26, 2012 at 9:52 PM / IP Logged
on off on switch wiring - Last Post -- posted image.
Posted: July 26, 2012 at 9:56 PM / IP Logged
Parking lights = whichever device you would want to run alone. Headlight = the other device.
1n4001 thru 1n4007 is a suitable diode.
badstr
Posted: July 27, 2012 at 12:07 PM / IP Logged
thank you thats what i needed
badstr
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
