07 saturn ion remote start
Talent421
Member - Posts: 10
Posted: November 17, 2012 at 7:20 PM / IP Logged
Hey guys,
I want to install a remote start in an 07 Ion and I need a diagram with as much detail as possible. I can't seem to find one for the 07. Only upto 06..........I would really appreciate any help.
Scott
Talent421
shortcircuit161
Silver - Posts: 556
Posted: November 17, 2012 at 9:15 PM / IP Logged
Here is a wiring diagram. You will need a data module to control the ignition and immobilizer. It will also control the power door locks. iDatalink makes a top notch module but needs to be programmed before using (as do most modules).
Make sure to test every wire before connecting anything to it. As for a diagram with as much detail as possible. This site has a lot of good general info to learn. I suggest you try there first.
12volts      red (40A)      +      BCM, black 37 pin plug, pin 37
Notes: The BCM (Body Control Module) is part of the fuse/relay box in the lower center of the dash, just below the HVAC control assembly.
Starter      yellow (not for remote start)      -      ECM, blue plug, pin 48, 46, or 56
Notes: The ECM (Engine Control Module) is on the driver side of engine compartment, near coolant over flow container.
Second Starter      white      mux      ignition harness or BCM, gray 56 pin plug, pin 53
If interface module is not available, see Tech Doc 1603.
Ignition      dk. blue      +      ignition harness or BCM, gray 56 pin plug, pin 7
Second Ignition      N/A
Third Ignition      N/A
Accessory      brown      +      ignition harness or BCM, gray 56 pin plug, pin 6
Second Accessory      same as second starter
Keysense      same as second starter
Power Lock      white      -      BCM, black 56 pin plug, pin 33
Power Unlock      same as power lock      -1.5K ohms
Lock Motor      gray      5 wire      BCM, black 56 pin plug, pin 51
Unlock Motor      tan      5 wire      BCM, black 56 pin plug, pin 2
Parking Lights+      brown      +      switch or BCM, gray 56 pin plug, pin 2
Parking Lights-      N/A
Hazards      lt. blue      -      switch or BCM, gray 56 pin plug, pin 40
Turn Signal(L)      lt. blue (F), yellow (R)      +      BCM, black 56 pin plug, pins 44 (F), 43 (R)
Turn Signal(R)      dk. blue (F), dk. green (R)      +      BCM, black 56 pin plug, pins 46 (F), 45 (R)
Reverse Light      lt. green      +      harness under driver seat
Door Trigger      lt. GREEN/ black      -      BCM, gray 56 pin plug, pin 45
Dome Supervision      white      -      BCM, black 56 pin plug, pin 11
Trunk/Hatch Pin      ORANGE / black      -      light in trunk
Notes: On models with keyless entry it is also dk. green at the BCM, black 56 pin plug, pin 35.
Hood Pin      N/A
Trunk/Hatch Release      BLACK/ white      +      switch or BCM, black 56 pin plug, pin 1
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and Passlock
Tachometer      NOT pink or pink/black      ac      any fuel injector
Wait to start      N/A
Brake Wire      lt. blue      +      switch or BCM, gray 38 pin plug, pin 8
Parking Brake      lt. blue      -      switch or BCM, gray 56 pin plug, pin 43
Horn Trigger      black      -      switch or BCM, gray 56 pin plug, pin 33
Talent421
Member - Posts: 10
Posted: November 18, 2012 at 8:01 AM / IP Logged
Thanks Frank!!
Talent421
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
