2001 Toyota Avalon XLS Remote Start
360glitch
Member - Posts: 10
Posted: December 18, 2012 at 8:56 AM / IP Logged
Thanks in advance for the help.
shortcircuit161
Silver - Posts: 556
Posted: December 18, 2012 at 10:00 AM / IP Logged
What help did you need? Your message is vague at best.
360glitch
Member - Posts: 10
Posted: December 18, 2012 at 10:22 AM / IP Logged
Sorry, I was looking for the wiring chart for this vehicle.
shortcircuit161
Silver - Posts: 556
Posted: December 18, 2012 at 10:34 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / AVALON / 2001 / Remote Start
[PRINT THIS PAGE]
12volts      wh/blu (40A), wh/red (10A)      +      ignition harness
Starter      BLACK/ white      +      ignition harness
Second Starter      N/A
Ignition      BLACK/ orange      +      ignition harness
Second Ignition      WHITE/ red      +      ignition harness
Third Ignition      N/A
Accessory      WHITE/ green      +      ignition harness
Second Accessory      N/A
Keysense      RED / yellow      -      ignition harness
Notes: Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.
Power Lock      see Tech Doc 1070
Power Unlock      see power lock
Lock Motor      blue/red      5wi      right side of the fusebox
Unlock Motor      blue/white      5wi      right side of the fusebox
Parking Lights+      use (-) wire only
Parking Lights-      pink      -      steering column or BCM
Notes: The BCM (Body Control Module) is attached to the bottom of the fuse box.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      RED / blue or red      -      right side of the fusebox
Dome Supervision      GREEN/ red      -      driver A pillar
Trunk/Hatch Pin      red      -      left side of the fusebox
Hood Pin      black      -      theft ECU
Notes: The theft module is located above the glovebox.
Trunk/Hatch Release      blue      -      switch on dash
Notes: Only works if main switch in the glove box is on.
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock      use key sense wire
Tachometer      black      ac      driver kick panel
Notes: Located in a gray plug, with the wires going up to the instrument cluster.
Wait to start      N/A
Brake Wire      RED / blue or GREEN / WHITE      +      brake switch or pass. kick
Parking Brake
Horn Trigger      GREEN/ black      -      steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:     Category:
Door Lock Interface     Required:
No     Type:
Data Bus
Part #: IM-Toyota-2
Notes:
Immobilizer Bypass     Required:
Yes     Type:
Transponder
Part #: 1100X
Alternate Part1 #: DesignTech 29402
Alternate Part2 #: 1100F
Alternate Part3 #: 555XW
Alternate Part4 #: 556UW
Alternate Part5 #: DesignTech 20402
Notes: The synch wire is blue / YELLOW, clock wire is blue/orange, data wire is pink/green, ignition wire is BLACK/ white, and ground wire is WHITE/ black. When using the 1100F, a software change to 1100TL is needed.
360glitch
Member - Posts: 10
Posted: December 18, 2012 at 10:40 AM / IP Logged
Thanks! Just wanted to doublecheck my other source.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
