wiring issue, 2002 honda accord
Platinum - Posts: 13,725
Posted: January 17, 2013 at 9:26 PM / IP Logged
The switch has nothing to do with it. You are feeding power to the illumination wire at the radio harness. Remove power from the illumination wire and problem will go away.
Or purchase a Metra 70-1721 harness, rewire the radio and call it a day.
bowser91
Member - Posts: 21
Posted: January 18, 2013 at 6:02 AM / IP Logged
So after that the lights will work at the switch again?
Posted: January 18, 2013 at 9:32 AM / IP Logged
I misread what you typed. You said Either where you should have typed Neither. But after you change the blown fuse, it will probably turn on with the switch.
bowser91
Member - Posts: 21
Posted: January 18, 2013 at 11:51 AM / IP Logged
Well disconnected the orange and now I'm not sure what fuse I'm looking for. The only only one i can think of is (day light) but there is no fuse in that spot. When i try to put one in it, it just falls out .... When i turn the switch on it clicks by the passenger side fuse box but no lights..
