Viper 5704 Will Not Go Into Programming
lurch228
Silver - Posts: 1,338
Posted: August 16, 2016 at 12:46 PM / IP Logged
You need to verify the ignition input is getting back to 5704 from the vehicle. H3/1 has to be hooked up in order to enter programming mode.
Or use a Bitwriter to change the settings on the 5704.
mraballard
Member - Posts: 10
Posted: August 17, 2016 at 5:59 PM / IP Logged
Thanks. I hooked up the pink wire from the remote start harness which allowed me to access the control center programming. I programmed for automatic transmission and then started getting an 8 flash error. So, I grounded the BLACK/ white wire from the 24-pin harness (wire 13) and still got the error. I realized it was because the on/off switch was not connected to the alarm. I didn't connect it because the CHTDH2 harness for the dball2 also has the on/off switch along with the hood switch, so I figured I didn't have to connect the switch for the alarm.
Now everything seems to be working. But, I am curious about the on/off switch for the dball2 CHTHD2 harness. What is that for? If I turn it on/off the remote start still works. Cheers!
ajb
lurch228
Posted: August 18, 2016 at 7:59 AM / IP Logged
Its for RSR installs on vehicles that already have OEM installed R/S. Too shutdown the DEI remotes from activating the OEM R/S VIA the DBALL/2/Pro.
mraballard
Member - Posts: 10
Posted: August 20, 2016 at 8:27 AM / IP Logged
Well I said everything seemed to be working fine, but that was before I actually got in to drive away. As soon as I let the emergency brake off, the car shuts down. I did ground the bkack/white on pin13 of the 24pin harness (h3?). Also, the alarm goes off after a short time if I remote start with the alarm active.
ajb
mraballard
Member - Posts: 10
Posted: August 20, 2016 at 9:57 AM / IP Logged
Scratch that, it's not when I release the ebrake, it's when I put my foot on the brake pedal, the car shuts down.
ajb
Posted: August 20, 2016 at 12:37 PM / IP Logged
Try turning on the ignition when you enter the vehicle. If it's a PTS this may be the norm.
Page of 3
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
