avital 4103 rs and pkall immobilizer
jen1110bill
Member - Posts: 41
Posted: March 03, 2013 at 3:33 PM / IP Logged
Im installing an avital 4103 remote start on a 1998 ford explorer using the express pkall module and cant seem to find where the blue/white wire on pkall module hooks to the avital unit. The manuel for express kit says to hook to (-) while running wire of avital unit but not sure which wire that is.
Also the xpress module wont program, I get to step 8a which is programming for auto trans which says - press and hold the programming button untill the led flashes once, then release- but the led never blinks, if I let go of programming button the led comes on and stys lit.
Any help is greatly appericated
bill
Posted: March 03, 2013 at 4:31 PM / IP Logged
Either satellite harness, pin 1 blue or H3 Blue/white labelled either GWR or "status output",
2nd. question, check your wiring and re-read the instructions.
smokeman1
Platinum - Posts: 1,589
I read that step 8a is activate the remote start is automatic.
Posted: March 03, 2013 at 4:34 PM / IP Logged
It's not the Xpress module it's the 4103 that won't program.
jen1110bill
Member - Posts: 41
Posted: March 03, 2013 at 5:10 PM / IP Logged
Thanks for the info ill recheck my wiring
bill
jen1110bill
Member - Posts: 41
Posted: March 04, 2013 at 8:28 AM / IP Logged
Ok have the blue/white wire correctly but another question the pink wire says to wire to ignition of vehicle, would that be ignition wire in switch for tumbler or ign wire at column? Thanks again for the help
bill
Platinum - Posts: 7,828
Posted: March 04, 2013 at 10:00 AM / IP Logged
The PKALL Pink wire can connect to the Avital 4103 thick Pink Ignition wire ( that continues to the Explorers GREEN/ Purple Ignition wire ).
Posted: March 04, 2013 at 10:16 AM / IP Logged
By definition:-
Ignition wire 0V on key out.
0V on ACC.
12V on ignition.
12V on start.
The wire that runs from the IGNITION SWITCH to various circuits enabling the engine to be started.
jen1110bill
Member - Posts: 41
Posted: March 05, 2013 at 7:55 AM / IP Logged
Thanks again for all the help, its been a couple years since doing any install so im a little rusty, just do it to help out freinds and family anymore so sorry if any questions seem repetious or lack of common sense.
bill
