clifford 650, 2002 bmw e46 coupe
reggy5gt
Posted: May 20, 2013 at 1:02 PM / IP Logged
Are there any alarm fitters that may be able to give me a little help with my Clifford 650, the problem I have is when I lock the car the doors instantly unlock, but if I activate remote start and remove the key from ignition I can lock okay, if I try and lock the car with the key in door it instantly unlocks, I've just fitted this alarm and it was removed from the same model and all the wires are where they should be.. any help much appreciated chaps
reggy5gt
Posted: May 20, 2013 at 1:10 PM / IP Logged
The car in question is a 2002 bmw e46 coupe
Posted: May 21, 2013 at 1:57 AM / IP Logged
This is the reason amateurs shouldn't install.
E46 is just about the easiest car if you follow procedure.
Is it an auto or a manual?
reggy5gt
Posted: May 21, 2013 at 8:57 AM / IP Logged
It's a manual, everything works fine except when I lock it unlocks instantly, I'm an amateur at alarms yes but I've done plenty of engine conversions ect including wiring, the central locking is wired up right as I have checked diagrams but I think the alarm senses there's a door open, just ordered a Clifford port cable for pc so if all else fails I can diagnose through that
