2013 dodge dart remote start
Raymond4646
Copper - Posts: 121
Posted: June 12, 2013 at 1:28 AM / IP Logged
racerjames76 wrote:
https://www.the12volt.com/installbay/forum_posts.asp~TID~78731~PN~1
More than likely you will encounter something similar to this as far as wiring into the doors. ROYAL PITA.2013 dodge dart remote start - Page 2 - Last Post -- posted image.
Yeah same bs my optima had. Fml. Thanks man
Raymond4646
Copper - Posts: 121
Posted: June 12, 2013 at 1:30 AM / IP Logged
kreg357 wrote:
D-Cryptor is Fortins' new process to load the bypass module with the captured transponder info. After the
initial program flash, you you will see that the bypass module is installed / connected to the vehicle, a few steps
are performed with the key in the ignition switch and then the bypass module is removed from the vehicle and
re-connected to the Flashlink2 updater / PC / internet connection for a little "massaging" before being re-connected
to the vehicle for final programming.
The "massaging" is the D-Cryptor process.
Ok yep this is straight protocol. Thought there was something else special to do. Thanks for the write up man!! Appreciate that!
