program viper 5704
haylee425
Posted: June 29, 2013 at 12:17 PM / IP Logged
I have installed the viper 5704. Everything work great. I have a issue with programming it double pulse unlocking. Every time I hit the unlock button on remote it only unlock the driver side door. Is there a way I can program to unlock all doors at once. For some reason I can't seem to select the option on menu one...
Also is there a way I can wire the alarm to roll up and down the window using the factory option Without adding a module still have 4 aux on my alarm i have a 05 Lexus rx330. On my factory fob I hold down unlocking it roll all window
Thanks in advance
Platinum - Posts: 7,828
Posted: June 29, 2013 at 3:22 PM / IP Logged
Might depend on the bypass module used and where the Vipers' lock wires are connected.
If you set the Viper to Double Unlock pulse, it should unlock all doors with the two pulses. Just change Menu 1,
Item 6 to Option 2. This assumes that the Vipers Blue Unlock wire is connected to this RX wire :
Factory Alarm Disarm      Gray (driver door key unlock) double (-)      @ driver door module in door   ***
There should be some previously posted Viper programming directions.
Getting the windows to roll-up with a Viper Lock command should be possible. Do this test. First roll down
the windows. With the engine off, insert the key into the drivers door lock cylinder, turn it to lock and hold it there
for 10 seconds. If the windows roll-up you can connect the Vipers Green Lock wire to this wire in the RX :
Factory Alarm Arm      Brown (driver door key lock) (-)     @ driver door module in door        ***
Set the Viper for Comfort Closure ( Menu 1, Item 9, Option 2 )
*** These RX Alarm wires do both lock / arm and unlock / disarm.
haylee425
Posted: June 30, 2013 at 5:49 PM / IP Logged
Thanks Kreg357
I got it to unlock all doors
I got the windows to roll up when arm. But when I disarm it roll down the windows about 1/4
Is there a setting not to roll down the windows when disarm?
Thanks for the help
Posted: June 30, 2013 at 6:12 PM / IP Logged
Try changing the Viper Menu 1, Item 7 to Option 3. This will give a .4 second pulse for a simple Lock and Unlock output.
haylee425
Posted: June 30, 2013 at 8:25 PM / IP Logged
I try changing it , still roll down windows about a 1/4 way on disarm
Posted: June 30, 2013 at 9:30 PM / IP Logged
Might need some more info.
What bypass module are you using?
Are the Vipers' Arm and Disarm wires connected to anything?
Do you have a BitWriter?
Any issues with the Factory Alarm?
haylee425
Posted: July 01, 2013 at 5:45 AM / IP Logged
I'm using pkall for bypass
Arm n disarm not hook up
I connected 2nd status from viper alarm to key sense to disarm factory. I try using factory disarm wire on viper 24 pin plug didn't work. When remote start factory horn would go off
Don't have a bitwriter
No issues with factory alarm
