2013 Nissan Sentra B17 Alarm/Remote Start/Stereo Wiring
ejsaba
Posted: August 15, 2013 at 3:00 PM / IP Logged
Can i get the wiring diagram for the sentra 2013? thanks!
Platinum - Posts: 7,828
Posted: August 17, 2013 at 9:27 AM / IP Logged
For vehicle wiring, here are some sources :
Here is a link to Ready Remote : http://www.readyremote.com/main.asp
Here is a link to AudioVox : http://techservices.audiovox.com/AccessRequest.aspx    Sign-up & info is free.
Posted: August 31, 2014 at 8:29 AM / IP Logged
I just downloaded it the the Downloads/Manuals section on this site look up 2013 Nissan Sentra.
tonanzith
Gold - Posts: 603
Posted: August 31, 2014 at 12:59 PM / IP Logged
This is for the basic 2013-16 Sentra not the smart key.
Item     Wire Color     Polarity     Wire Location
12 Volts     green (40A)     +     ignition switch, white 6 pin plug, pin 3
Second 12 Volts     N/A
Starter     blue     +     ignition switch, white 6 pin plug, pin 2
Second Starter     N/A
Ignition     red     +     ignition switch, white 6 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     pink     +     ignition switch, white 6 pin plug, pin 4
Second Accessory     white     +     ignition switch, white 6 pin plug, pin 5
Third Accessory     N/A
Keysense     gray     +     ignition key switch, gray 6 pin plug, pin 1
Data Bus     pink (clock); lt. green (data)     data     NATS antenna amp on ignition key switch, wht 4 pin plg, pins 2, 4
Can Bus High     blue     data     data link conn or BCM bhnd dash fuse box, white 40 pin plug, pin 39
Can Bus Low     pink     data     data link conn or BCM bhnd dash fuse box, white 40 pin plug, pin 40
Can Bus Sw     N/A
Power Lock     gray     -     BCM behind dash fuse box, white 40 pin plug, pin 12
Power Unlock     brown     -     BCM behind dash fuse box, white 40 pin plug, pin 13
Lock Motor     orange     5 wire     BCM behind dash fuse box, white 15 pin plug, pin 11
Driver Unlock Motor     lt. blue     5 wire     BCM behind dash fuse box, white 15 pin plug, pin 9
Passenger Unlock Motor     lt. blue     5 wire     BCM behind dash fuse box, white 15 pin plug, pin 12
Parking Lights (-)     N/A
Parking Lights (+)     purple     +     passenger kick, white 16 pin plug, pin 5
Hazards     lt. blue     -     BCM behind dash fuse box, white 40 pin plug, pin 29
Turn Signal (Left)     lt. green     +     BCM behind dash fuse box, black 15 pin plug, pin 1
Turn Signal (Right)     orange     +     BCM behind dash fuse box, black 15 pin plug, pin 2
Headlight     blue (L), pink (R) (LO); green (L), yellow (R)(HI)     +     underhood fuse box, white 16 pin plug, pins 5, 6; 4, 3
AutoLights     N/A
Reverse Light     gray     +     driver kick, white 12 pin plug, pin 12
Left Front Door Trigger     yellow     -     BCM behind dash fuse box, black 15 pin plug, pin 6
Right Front Door Trigger     red     -     BCM behind dash fuse box, black 15 pin plug, pin 5
Left Rear Door Trigger     gray     -     BCM behind dash fuse box, black 15 pin plug, pin 7
Right Rear Door Trigger     pink     -     BCM behind dash fuse box, black 15 pin plug, pin 8
Dome Supervision     brown     -     BCM behind dash fuse box, white 15 pin plug, pin 5
Trunk/Hatch Pin     purple     -     BCM behind dash fuse box, black 15 pin plug, pin 11
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     blue     -     release sw or BCM behind dash fuse box, white 40 pin plug, pin 30
Trunk Release Motor     gray     5 wire     BCM behind dash fuse box, black 15 pin plug, pin 15
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     purple (driver door key lock)     -     BCM behind dash fuse box, white 40 pin plug, pin 8
Factory Alarm Disarm     blue (driver door key unlock)     double -     BCM behind dash fuse box, white 40 pin plug, pin 7
Disarm No Unlock     (see factory alarm disarm)
Trunk Alarm Shunt     N/A
Tachometer     orange, purple, lt. blue, or brown     ac     any fuel injector, gray 2 pin plug, pin 2
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     brown     +     clutch switch, brown 2 pin plug, pin 2
Fuel Pump     pink     +     driver kick, white 4 pin plug, pin 1
Rear Defroster     white     -     BCM behind dash fuse box, white 40 pin plug, pin 10
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     gray     5 wire     left heated seat switch, white 6 pin plug, pin 5
Right Front Heated Seat     blue     5 wire     right heated seat switch, brown 6 pin plug, pin 5
Speed Sense     yellow (some models)     8-Pulse     radio, white 20 pin plug, pin 18
Brake Wire     lt. blue to red     +     brake switch or BCM behind dash fuse box, white 40 pin plug, pin 9
Parking Brake     lt. blue     -     parking brake switch, black 1 pin plug, pin 1
Horn Trigger     red     -     horn switch, yellow 6 pin plug, pin 3
Wipers     white (LO); blue (HI)     +     underhood fuse box, brown 12 pin plug, pins 11, 5
Left Front Window (Up/Down)     orange - gray     A     power window main switch, white 3 pin plug, pins 1 - 3
Right Front Window (Up/Down)     white - brown     A     driver kick, door harness, white 55 pin plug, pins 11 - 12
Left Rear Window (Up/Down)     red - pink     A     driver kick, door harness, white 55 pin plug, pins 7 - 8
Right Rear Window (Up/Down)     lt. green - yellow     A     driver kick, door harness, white 55 pin plug, pins 9 - 10
Sun Roof (Open/Close)     red - green (function with ignition on only)     -     moonroof switch, white 12 pin plug, pins 3 - 10
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     yellow     +     radio, white 20 pin plug, pin 19
Radio Ground     (chassis on base audio); black (except base audio)     -     radio, white 20 pin plug, pin 20
Radio Ignition     pink     +     radio, white 20 pin plug, pin 7
Radio Illumination     red (parking lights); gray (dimmer, w/o navi)     +,-     radio, white 20 pin plug, pins 9, 8
Factory Amp Turn-on     gray     +     radio, white 20 pin plug, pin 1
Power Antenna     black     +     radio, gray 3 pin plug, pin 1
Left Front Speaker (+/-)     blue - pink     +,-     radio, white 20 pin plug, pins 2 - 3
On models with Bose, the speaker wires are white - yellow at the amplifier under the rear deck, brown 23 pin plug, pins 20 - 19. The tweeter wires are gray - lt. blue at the amplifier, brown 14 pin plug, pins 14 - 13.
Right Front Speaker (+/-)     lt. blue - purple, or green - red     +,-     radio, white 20 pin plug, pins 11 - 12
On models with Bose, the speaker wires are lt. blue - purple at the amplifier under the rear deck, brown 23 pin plug, pins 7 - 6. The tweeter wires are pink - purple at the amplifier, brown 14 pin plug, pins 11 - 12.
Left Rear Speaker (+/-)     lt. green - white, or lt. green - purple     +,-     radio, white 20 pin plug, pins 4 - 5
On models with Bose, the speaker wires are green - gray at the amplifier under the rear deck, brown 23 pin plug, pins 10 - 23.
Right Rear Speaker (+/-)     brown - yellow     +,-     radio, white 20 pin plug, pins 13 - 14
On models with Bose, the speaker wires are white - orange at the amplifier under the rear deck, brown 14 pin plug, pins 1 - 6.
Center Channel (+/-)     N/A
Subwoofer (+/-)     yellow - blue (L); red - white (R)     +,-     amplifier under rear deck, brown 14 pin plug, pins 2 - 7; 10 - 9
Aux. Audio Input Left (+/-)     red - black (with navigation)     +,-     radio, white 24 pin plug, pins 10 - 11
Aux. Audio Input Right (+/-)     white - black (with navigation)     +,-     radio, white 24 pin plug, pins 12 - 11
RSE Video (+/-)     purple - (shield) (rear view camera)     +,-     radio, white 24 pin plug, pins 16 - 15
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.5     3.2     left front door
Left Front Tweeter     1     1     left front pillar
Right Front Speaker     6.5     3.2     right front door
Right Front Tweeter     1     1     right front pillar
Left Rear Speaker     6.5     3.0     left rear deck (w/o Bose); rear door (w/Bose)
Left Rear Tweeter     N/A
Right Rear Speaker     6.5     3.0     right rear deck (w/o Bose); rear door (w/Bose)
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     6.5     3.0     left and right rear deck (w/Bose)
Left Front Headrest
Gary Sather
tonanzith
Gold - Posts: 603
Posted: August 31, 2014 at 1:02 PM / IP Logged
Sorry. That's 2013 sentra. Damn spell check....
Gary Sather
Posted: August 31, 2014 at 1:14 PM / IP Logged
LOL The one on my PC still makes me change "ENERGISE" UK spelling to "ENERGIZE" US spelling except it won't alter CENTRE.
Damn it did that time2013 Nissan Sentra B17 Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
tonanzith
Gold - Posts: 603
Posted: August 31, 2014 at 1:23 PM / IP Logged
Lol. Mine is English yet it changed sentra to a Spanish word.
Gary Sather
