07 ion no starter wire
coolen
Copper - Posts: 121
Posted: October 30, 2013 at 5:32 PM / IP Logged
got everything hooked up. the idatalink module registered the programming correctly- so I proceeded to learn the tach, but the car wont start with the key. I'm gonna continue to recheck everything..but i'm getting stumped.......
the door locks work along with the trunk via the remote
Platinum - Posts: 7,827
Posted: October 30, 2013 at 5:47 PM / IP Logged
Which Brand / Model remote starter did you use?
Which bypass module did you get?  What firmware is flashed on it?
coolen
Copper - Posts: 121
Posted: October 30, 2013 at 6:42 PM / IP Logged
I used a pro start 3200. I've traced the problem down to the passlock circuit. I can take the idatalink out of the equation and it starts. when it's hooked back up, the park lights flash 3 times......
I used the gm4 firmware
is it possible that the idatalink schematic is backwards for the passlock hook up? I have the WHITE/ red wire tied into the yellow, which goes to the car side of the passlock wire, and the WHITE/ black goes to the connector side........
thanks for your reply- oh, and i'm using the ads-al-ca mod
Posted: October 30, 2013 at 7:10 PM / IP Logged
Their WEB site is down again.   07 ion no starter wire - Page 2 - Last Post -- posted image.   I can't get the ADS AL CA with ADS AL(DL) GM4 firmware install guide...    07 ion no starter wire - Page 2 - Last Post -- posted image.
Typically, their install guides are 100% accurate.
coolen
Copper - Posts: 121
Posted: October 30, 2013 at 7:13 PM / IP Logged
I talked to one of their techs... and he said that it was possible that their was a faulty relay inside the module. I'm sooooo frustrated!! I wish I had an option.
Website down eh? hmmmm, I'm on it.........
Posted: October 30, 2013 at 7:53 PM / IP Logged
A bad module is pretty rare...
What they don't show you on the Type 1 Diagram are some important remote starter connections.
The R/S thick Ignition wire should connect to the ION Main Ignition connector Dark Blue wire at Pin 3 along
with the ADS AL CA's Pink wire.
The R/S thick Accessory wire should connect to the ION Main Ignition connector Brown wire at Pin 4
along with the ADS AL CA's BLACK/ White wire.
Also sounds like the bypass module didn't fully program.  Think I would do a Factory reset on it.  Set the
Install Mode again, then do the programming again.  Make sure to wait the 3 seconds at each step as
shown in the instructions.  ( Hold the key at START for 3 seconds, it won't grind / over crank ).
coolen
Copper - Posts: 121
Posted: October 31, 2013 at 7:34 AM / IP Logged
Thanks for all the replies. All it took was for the idatalink module to be reprogrammed. Phew!
Thanks to all once again!!
This Ion wasn't too bad of a job at all. If it weren't for the idatalink issue it would have went flawless!!
For future installs...use the orange wire on the ignition module for the tach. I believe it was marked "G" on the connector.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
