07 santa fe unlock
ziggyb222
Silver - Posts: 593
Posted: November 17, 2013 at 10:53 AM / IP Logged
Seeing on some tech sheets about hooking the disarm wire along with the unlock wire? Is this correct?
triniforever
Copper - Posts: 323
Posted: November 17, 2013 at 3:45 PM / IP Logged
Yes that's correct . The reason being that sometimes on Hundai's when the car is locked with the key , factory fob or the door lock switch it will not reopen with the aftermarket remote unless it "see's" a key in the door , A relay and three diodes needs to be integrated with the unlock and disarm wire for the aftermarket remote to work .
triniforever
Chris Luongo
Platinum - Posts: 3,746
Posted: November 19, 2013 at 7:22 AM / IP Logged
You shouldn't need to connect the unlock wire at all.
Send a double pulse to the disarm wire, and a double pulse to the unlock detection (gray), at the same time. This will unlock all doors and disarm factory alarm.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
