2001 buick century vats transponder wires
jr789
Member - Posts: 23
Posted: December 07, 2013 at 10:42 PM / IP Logged
Hi 2001 buick century vats transponder wires - Last Post -- posted image.
     When wiring the Direct electronics universal bypass module # 20402 or 29402. Does it matter which of the two wires from the key are cut and which is spliced ie the Prpl/blk or Wht/blk? There is no indication in the schematic indicating so. Is this because the circuit is basically a loop?
    P.S What is a good 12 volt source for the grn/wht wire? Shouldn't it be connected to a fused source? How many amps if so?
     Thanks in advance 2001 buick century vats transponder wires - Last Post -- posted image.
Platinum - Posts: 7,828
Posted: December 09, 2013 at 5:53 PM / IP Logged
Have you located your VATS wires in the Century yet?  It's been a while since I did one of these, but I
remember them being very thin, delicate, White wires in an Orange tube.  You can cut and splice into either
one.  They are a real PITA to solder, so try to use a 25W or 40W pencil iron.
As for the +12V power, I usually just connect that to the R/S's main power input wires, after the fuse.  The
bypass module does not use very much power.  If you want to fuse it, go for 3 or 5 Amps.
jr789
Member - Posts: 23
Posted: December 09, 2013 at 8:26 PM / IP Logged
      Kreg , yes i found them , i connected them past the plugin connector ,(the two color coded 20g wires) (but in the beginning cut the fine vats wires and re-soldered them (a test of nerves) The transponder is still not sending a signal to the brain, a local directed installer said do away with the vats system with a resistor. I would still like to get the transponder to override the ignition. Any ideas why the brain would not be getting a signal from the transponder ??
Posted: December 09, 2013 at 9:09 PM / IP Logged
VATS is a fairly simplex system.  Those two wires go up into the ignition switch and make contact with the resistor in
the inserted key.  I have always used those two thin VATS wires and connected close to the switch itself.  Your 29402
bypass module is nothing more than a relay and the correct "dip switch selected" resistor, similar to this Audiovox VATS
bypass diagram  :  http://documents.audiovox.com/700052.pdf    If I remember correctly, there is a security or theft light
on the dash that goes out when the key is inserted and turned to START.  The same thing should happen when you
apply chassis ground to the bypass modules' GWR wire and a R/S is initiated & cranks the starter.
If the security light is blinking, the car will not start-up, even with the problem corrected.  It's a 4 minute time out.
Directed has a kit ( 652T ) that has the 15 correct resistor values ( ~ $5 ) that you could use with a relay to do the bypass.
If you were installing an alarm system or having issues with the ignition cylinder going bad and putting the car in Tamper
Mode, you could do as the local shop said, just solder in the correct resistor and no more VATS.
Here is a link to more info on the VATS system  :  http://www.thirdgen.org/vats_passkey_system
jr789
Member - Posts: 23
Posted: December 11, 2013 at 8:54 PM / IP Logged
Thanks Kreg
      The light bulb just came on 2001 buick century vats transponder wires - Last Post -- posted image.
That must be where i have made a mistake by connecting it to the wires past the ignition cylinder vats wires. (where they plug into the harness).
        Hopefully the weather will hold out so i can make the necessary changes this weekend.
        Thanks again !!!!!!!
