grounding issue with turn signal module
deucekiller
Posted: December 09, 2013 at 9:24 PM / IP Logged
Hi everyone,
I have been searching on here but have not found a solid answer
I am wiring my vehicle from scratch (kit car) and have a SDC turn signal module.
http://www.signaldynamics.com/penta-star-module/
install instructions
https://store-wfdoukr.mybigcommerce.com/content/1007%20Penta%20Star.pdf
right now the vehicles gauges are messing with the ground and causing the module to not work.
Is there a way to isolate the ground. I saw this setup
https://www.the12volt.com/relays/relaydiagram46.html
Would this work in this case or do I need a diode?
oldspark
Gold - Posts: 4,913
Posted: December 10, 2013 at 2:21 AM / IP Logged
How is the gauge GND messing with the GND?
GND should be GND - there is no need for isolation.
Do you mean you need a heavier or independent GND between the 2? If so, split them.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
