smart start experts
dkjeep
Member - Posts: 11
Posted: December 18, 2013 at 1:17 PM / IP Logged
It states it on pages 9 and 15 clearly in bold print with an exclamation mark next to it for the manual for my application.
I'm so lost. I really wanted this to work.
smokeman1
Platinum - Posts: 1,589
Posted: December 18, 2013 at 2:26 PM / IP Logged
Which type install are you doing? 3 a, b or c? Was there a remote starter already in the Jeep connected to the DB-ALL?
Since it states to ground the grey wire and you don't have one, maybe the brown should be the (-) ground. I looked at a VSM200 I have on hand and it has a brown and white loop. No Grey.
Did you connect the modules in the specific order stated? Damage to the DB-ALL could occur. Page 15 install guide.
And where does it state to cut a wire. Just wondering. I didn't see it.
EDIT: I see on the SmartStart install guide it states to cut the brown wire for D2D, but I believe that is for connection to a remote start system, not a DB-All.
smokeman1
Posted: December 18, 2013 at 3:44 PM / IP Logged
I took a DB-ALL, 12volt and ground only, and connected it to a VSM200 with the White D2D, grounded the brown wire.
Only got the solid amber light. Unplugged the DB-ALL, grounded the white, got the solid amber and then got a solid green for a moment, then both LEDs flashed a few times, flashing amber, solid amber, no green.
I can only guess since I don't have the proper connections to the vehicle It won't get a solid Green.
I then connected the vsm200 to a bench test Viper unit I have and acquired solid LED on amber and green.
You might have to SWAG it. (Sophisticated, Wild Ass Guess)
dkjeep
Member - Posts: 11
Posted: December 18, 2013 at 5:22 PM / IP Logged
Man thank you so much. I am going to try everything that you mentioned when I get home tomorrow and I will report back and let you know what happens. I read to cut the brown loop on another setup sheet for the dsm200 somewhere online. I have been having to piece together info out of several Information pdf files.
dkjeep
Member - Posts: 11
Posted: December 18, 2013 at 5:26 PM / IP Logged
Also the jeep does not have a factory remote start and I have followed the instructions to the letter on the connection order. I read the instructions thoroughly before I started this.
dkjeep
Member - Posts: 11
Posted: December 20, 2013 at 3:13 PM / IP Logged
Well crap. I tried everything thatyou sai dthat you did and nothing worked. No matter how I had it setup I would get a green light flash and that was it. The orange works perfect every time but the green will only flash once when plugged in and thats it.
Any other ideas?
dkjeep
Member - Posts: 11
Posted: December 20, 2013 at 4:11 PM / IP Logged
GOT IT!!!!!!!!!!!!!! I traced the wires in the extension harness that goes between the smart start and the dball and the transmit and receive wires were not in the same order as they were coming out of the smart start. I used a pic to carefully remove them form the connector and switched them around and BOOM!!!!! its working. All that crap because the wires were flipped around form the factory. Thanks for trying guys but in the end nobody could have figured this out without being here.
dasbogie
Silver - Posts: 514
Posted: December 20, 2013 at 4:12 PM / IP Logged
By chance was there an addendum leaflet in the smartstart packaging?
Advanced
smokeman1
Posted: December 20, 2013 at 6:10 PM / IP Logged
So, the wire colors didn't match up at the black connector? Just wondering.
dkjeep
Member - Posts: 11
Posted: December 21, 2013 at 2:48 AM / IP Logged
Correct the red and black wires were matched up for power but the blue and green were not. I just didn't catch it until today when I was really looking at everything through a microscope.
I saw no additional reading material in the package mentioning this even being a possibility if that is what you were referring to.
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
