viper 5701 neutral saftey switch fix
jsolts
Member - Posts: 49
Posted: January 02, 2014 at 6:36 AM / IP Logged
Hey Guys,
Was cleaning up a rookie install of a Viper 5701 Remote Start Combo in a 2007 GMC Sierra Classic Automatic.
I had taken all the equipment out of the vehicle while i cleaned up the wiring when i accidentally dropped the neutral safety switch on the ground without noticing.
By the time i realized what i had done, another worker had ran it over and crushed it to pieces.
Now i have 2 options, replace the switch, or find a work around.
I attempted to cut the switch off of the wire leads and connect the two leads together, but it did not work.
Now everytime i try to remote start i get 8 flashes error (neutral saftety switch)
Since this is a automatic vehicle, do i really need this switch installed.
Does anyone know a work around for this? Or do i need to replace this switch?
Twelvoltz
Platinum - Posts: 2,384
Posted: January 02, 2014 at 10:55 AM / IP Logged
8 flashes is "toggle switch off". I'd just feed it a ground and call it a day. The 07 Sierra has a factory neutral safety, it won't crank in gear.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
