blade al + pts
cutegelo
Posted: January 09, 2014 at 3:25 PM / IP Logged
I just bought a cm6000 + blade-al for my 2011 Honda Civic Si. I want to add a aftermarket PTS from advance keys. I was reading the install manuals and I'm having a hard time figuring out which wire from the PTS should I connect to the blade-al harness, so that the bypass could be used with advance key's PTS.
Also, could anyone point me which wire should I bypass since I'm using blade-al? besides door locks?
Thanks in advance.
cutegelo
Posted: January 09, 2014 at 3:29 PM / IP Logged
here's the advance key PTS install manual in pdf version.
http://www.advancedkeys.com/docs/AK-PSB05.pdf
enice
Silver - Posts: 857
Posted: January 10, 2014 at 12:23 AM / IP Logged
its better to use a ads tb to do bypass and not the blade AL. This job is very time consuming and not easy. I have done a few cars with the compustar system and it has worked flawless. Good Luck
Eric
Audiomaxx
528 East Fordham Road
Bronx NY 10458
Compustar Top Gun Dealer Award 2012-2013
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
