directed 4103 remote start
pregunta
Member - Posts: 12
Posted: January 26, 2014 at 9:41 PM / IP Logged
Yeah. I always over think things. I was thinking the unit was an interupt. It is more like a piggy back. Thank you for putting me back on track. The last one of these I did was about 10 years ago.
I did on on a 95 integer and a 2000 grand am. Just used the door triggers to activate the remote start so the OEM remotes could be used. Bbut the polarity is different on this car.   I will try reversing the polarity with a relay.
Thank you again.
itsyuk
Silver - Posts: 505
Posted: January 26, 2014 at 11:08 PM / IP Logged
make sure the hood isnt open... LOL
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
pregunta
Member - Posts: 12
Posted: February 03, 2014 at 10:19 AM / IP Logged
Let me start by saying, "I hate the BCM in this car". I like to Use the OEM key fob to keep things neat and clean. Using the horn ground signal (don't ask) and three pulses the car started perfectly. I found out the hard way that once the car is started the BCM shuts down all usage of the OEM key fob. "In my day, Cars didn't think for you" -Grumpy Old Man
So I went in and wired the remote start to use the aftermarket Key fob. Using the wiring in the drivers side kick and hazard relay control at the BCM.
All works fine now. Thank you for the help and the wiring diagrams were invaluable. I bought a FSM for this car. If anyone needs print outs, let me know.
ggora
Member - Posts: 9
Posted: February 03, 2014 at 12:58 PM / IP Logged
Pregunta,
Maybe you can help answer a question I posted yesterday. I just installed the 4103 in a 2001 Dodge Ram. I have found if I leave the doors unlocked (and closed), then start the truck remotely the doors do not lock.
The lock/unlock on the remote works fine otherwise. Just wondering if the unit is supposed to lock the doors on remote start. I know my 5901 does in my other car.
pregunta
Member - Posts: 12
Posted: February 03, 2014 at 3:20 PM / IP Logged
I don't think they do. But you could use another output to trigger them. I will check the manual tonight when I get home.
chev104275
Gold - Posts: 1,436
Posted: February 03, 2014 at 3:39 PM / IP Logged
I usually use the negative start output (purple in the small 4 wire harness) use a diode to prevent feedback.
pregunta
Member - Posts: 12
Posted: February 03, 2014 at 9:50 PM / IP Logged
Could he split/diode and use the light GREEN/ black factory disarm also? I pulses negative once the remote start is activated. The install guide I found doesn't cover the satellite harness.
chev104275
Gold - Posts: 1,436
Posted: February 04, 2014 at 4:04 AM / IP Logged
He would have to check you believe you can set the disarm wire to pulse on remote start only. So yes that could be an option. But If his truck has a factory alarm then you would also need it to pulse on the unlock command which wouldn't be what you want.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
