car would not turn off
sabarni
Posted: April 29, 2014 at 10:08 AM / IP Logged
I just finished installing a Viper 5704 + Dball, firmware Mazda 1.10.14, on a 2009 Mazda 6 push button start, but I can’t turn off the remote start with the transmitter once is started, and is set for 12 min runtime, even after the time expired the car is still running and I’m getting an alert “key is on”. Do you guys have any suggestion why is this happening?
racerjames76
Silver - Posts: 581
Posted: May 07, 2014 at 9:47 AM / IP Logged
Have not used that hardware on that car but it obviously sounds like either the dball is not turning off after shutdown or there is a data problem and the dball is not pulsing the PTS to turn the car off..
To master and control electricity is perfection. *evil laugh*
Ravendarat
Platinum - Posts: 2,806
Posted: May 08, 2014 at 7:06 PM / IP Logged
Uh your key isn't near the vehicle when you are trying this are you?
sabarni
Posted: May 12, 2014 at 10:11 AM / IP Logged
I did talk to tech support, and apparently there is a new install and firmware for this car because the older version was "buggy", so I did change the few wires as per new diagram the Rx does not needs to be cut so I soldered back and removed the unnecessary wires, I will try to load the new firmware hopefully would help. I will post back once I'm done with the flash. Btw any of you had a same setup/car installation?
racerjames76
Silver - Posts: 581
Posted: May 12, 2014 at 10:41 AM / IP Logged
Still not sure what your issue is, but I am wondering if a simple pulse from the shut down wire or factory alarm rearm wire to the PTS wire would shut it down properly?
sabarni
Posted: May 13, 2014 at 12:10 PM / IP Logged
So I did the software flash, and did help the car starts up and I can turn it off with the remote also I hooked up the windows+sunroof and does work, but there is still an issue the car not always starts up, fails to crank or cranks just a little bit, any thoughts?
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
