viper 4706v remote start
rajubhai55
Posted: August 08, 2014 at 8:53 PM / IP Logged
Hi,
I have currently have Crimestopper RS900 remote start installed in my 2001 Camry.It is a basic remote start and works fine but the range is too short. I want to replace it with Viper 4706V remote start. I want to use only as remote start nothing else.
Below are the three diagrams which shows:
1. Ignition and starter connections (Blue arrows). My current remote start are connected at these locations (output from remote starter module)
2. Tachometer connection is taken from wire going from Engine control unit to instrument cluster.
3. Connections available for remote start on new Viper 4706v are shown.
My questions are
Which wires (for ignintion and starter) from Viper showuld be connected to the points in camry diagram showns by blue arrows.
Am I correct in connecting the tachometer wire (Violet/white) connected to tachometer shown in second diagram for camry?
If diagrams are not clear let me know, i will try to upload again. Any help would be highly appreciated.
Thanks,
viper 4706v remote start - Last Post -- posted image.
Raj the great
catback
Silver - Posts: 703
Posted: August 09, 2014 at 1:05 AM / IP Logged
Pink/White on the viper is your Ignition 2 (Blk/Red)
Violet on the Viper is your Starter (Red)
It goes without saying you'll need to hook up the RED / Black, Red, and RED / White to +12v sources.
Viper RED / White to Camry WHITE/ Red
Viper Red to Camry White
Viper RED / Black to Camry WHITE/ Red
Yes you are correct about the tach wire.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
