for viper 5706v pro’s, 2014 tacoma
je3169
Copper - Posts: 73
Posted: October 23, 2014 at 9:29 PM / IP Logged
OK so before I tear open my truck again if I put my key in the ignition and remote start the truck the locks should not unlock right?
John
flobee4
Silver - Posts: 585
Posted: October 24, 2014 at 12:28 AM / IP Logged
I actually called Idatalink on this. If you have a factory alarm on a Toyota in order to disarm it without unlocking the doors you would power up the keysense wire on the car while remote started. The problem is the the installation manual for the idatalink TL5 firmware specifically says do not power up the keysense. They say the only way to disarm the factory alarm now is to have the doors unlock before starting and relock after it starts. Since you have a viper 5706 you can set it to relock simply by turning on the "safelock" feature through the 5706 programmable feature at menu 3 feature 16.
je3169
Copper - Posts: 73
Posted: October 24, 2014 at 6:24 AM / IP Logged
UPDATE I found my error when I installed my 5706 I used the factory arm and disarm for the lock and unlock I do not have a factory alarm so I did not think it would make a difference butttt now I know why it is doing what it is doing so later today I will run the lock and unlock wires.
Thanks for all the help guys
John
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
