98 legacy alarm/remote start
max626
Posted: November 10, 2014 at 2:47 PM / IP Logged
I recently installed a AutoPage C3-RS-730 Alarm/Remote Start in my 1998 Subaru legacy 5spd. The alarm side functions properly but I'm haven trouble getting the remote start to work. I program the remote start and when I go to start it with the remote it says "Engine stop". What could be the issue is there a wire that I'm missing to hookup? Also i bypassed the clutch *temporally* so that i could verify the remote start function would operate correctly before adding a bypass relay.
http://remotelystartedmn.com/admin_files/PDF/C3-RS-730install1.pdf
shark mobile
Copper - Posts: 83
Posted: December 25, 2014 at 10:43 PM / IP Logged
Pretty sure there's no need for a bypass on that vehicle...however you need to tag park brake, and door triggers as well as the clutch...with that said almost all remote starters on manual transmission vehicles have an arming sequence...if you do not follow the arming sequence the remote start will not operate.   It is a safety feature...
Solder, tape, repeat!
Platinum - Posts: 7,827
Posted: December 26, 2014 at 4:00 AM / IP Logged
At the top of Page 4, the C3-RS-730 LCD “ Multi-Color “ Installation Manual has this warning :
This Remote Starter with Alarm and Keyless Entry System has been designed to be installed on fuel-injected vehicles
with an automatic transmission ONLY.
  Never install this remote starter on a manual transmission vehicle.
That being said where do you have this wire connected to in your manual transmission car?
H6/8 BLACK/ WHITE WIRE – (-) Neutral Safety Switch Input or (-) Enable Switch Input
Saturday, November 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
