avital 4103 1996 lincoln towncar
coyn11
Member - Posts: 14
Posted: January 04, 2015 at 10:57 PM / IP Logged
Tomorrow I am digging into the install. I'm just wanting to check all my wiring. I'm probably forgetting something. Also, do I need relays? Diodes?
Main Harness (H1), 9 Pin connector
  1. Factory disarm - drk grn/prpl
  2. NC
  3. ignition out(to alarm) - to ignition BROWN / pink
  4. activation input - NC
  5. ground when locked/antigrind output - NC
  6. Horn output - Drk Blue
  7. trunk release - to purple / YELLOW
  8. ground - chasis ground
  9. light flash output - brown
Door Lock - 3 pin connector
  1. unlock - to pink/light green
  2. empty
  3. lock - to pink / YELLOW
Heavy Gauge Relay H2, 6 pin connector
  1. output to primary ignition circuit - BROWN / pink
  2. output to starter circuit - WHITE/ pink
  3. output to accessory circuit - BLACK/ light green
  4. 30A high current 12v input - light green
  5. output to second ignition / accessory circuit - pink/black
  6. 30A high current 12 v input - light green
Satellite harness - 4 pin connector
  1. status output - NC
  2. accesory output - BLACK/ light green
  3. starter output - WHITE/ pink
  4. ignition output - BROWN / pink
Remote start Harness H3 5 pin connector
  1. neutral safety switch input - grounded
  2. tach input - pink @EDIS module
  3. brake shutdown input wire - light green @ brake
  4. hood pin switch shut down wire - to hood pin
  5. second status/rear defogger - I want this hooked up, but i dont know where it goes.
noob
chev104275
Gold - Posts: 1,436
Posted: January 05, 2015 at 4:54 AM / IP Logged
On H1 ignition out doesn't go to anything, satellite harness doesn't go to the ignition harness. The satellite harness has all negative outputs made to run external relays.
Door locks are positive trigger and the 4103 has negative outputs you will need a pair of relays or a dei 451m
POWER LOCK      PINK / YELLOW (TYPE A)      IN DRIVERS KICK PANEL
POWER UNLOCK      PINK/LIGHT GREEN (TYPE A)      IN DRIVERS KICK PANEL
coyn11
Member - Posts: 14
Posted: January 05, 2015 at 12:04 PM / IP Logged
First off, Thank you Chev for the reply.
Second, on the cheat sheet I printed off I saw 3 ignitions. How do I hook then up?
Ign 1- primary ignition - BROWN / pink
Ign 2- heat/ac - pink/black
Ign 3- blower motor     - BLACK/ lt gen
noob
tedmond
Gold - Posts: 4,610
Posted: January 05, 2015 at 12:58 PM / IP Logged
The 4103 has 2 ignition outputs. The third you'll need the negative ignition wire from the satellite harness; and connect that to a relay as follows
85 negative ignition output
86 constant 12v fused
87 constant 12v fused at 15-20 amps
30 third ignition wire
Ted
Compustar Expert
coyn11
Member - Posts: 14
Posted: January 05, 2015 at 1:43 PM / IP Logged
Sweet, thanks guys! Time to dig in!
noob
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
