2012 mazda5 remote start
funkypc
Posted: January 08, 2015 at 2:17 PM / IP Logged
I'm installing a remote start system in my 2012 Mazda 5 and am wondering if someone could help me find the wiring colors and locations for the factory alarm/remote start system.
Thank you
tonanzith
Gold - Posts: 603
Posted: January 08, 2015 at 2:28 PM / IP Logged
12 Volts     blue/black (40A)     +     ignition switch, white 8 pin plug, pin 8
Second 12 Volts     black (50A)     +     ignition switch, white 8 pin plug, pin 4
Starter     blue/red     +     ignition switch, white 8 pin plug, pin 5
Second Starter     N/A
Ignition     blue     +     ignition switch, white 8 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     BLACK/ red     +     ignition switch, white 8 pin plug, pin 6
Second Accessory     BLACK/ white     +     ignition switch, white 8 pin plug, pin 7
Third Accessory     N/A
Keysense     blue     +     ignition switch, white 8 pin plug, pin 2
Data Bus     blue/orange (TX), gray (RX)     data     PATS Transceiver around ignition switch, white 4 pin plug, pins 2, 1
Can Bus High     BLACK/ red (MS CAN); GREEN/ YELLOW (HS CAN)     data     data link connector, black 16 pin plug, pins 3, 6
Can Bus Low     WHITE/ red (MS CAN); RED / yellow (HS CAN)     data     data link connector, black 16 pin plug, pins 11, 14
Can Bus Sw     N/A
Power Lock     blue     -1000 ohms     either kick or BCM behind glove box, white 24 pin plug (6), pin 14
Power Unlock     (same as power lock)     -
Lock Motor     RED / blue to RED / yellow     5 wire     either kick or BCM behind glove box, white 16 pin plug (5), pin 8
Driver Unlock Motor     RED / black     5 wire     either kick or BCM behind glove box, white 16 pin plug (5), pin 7
Passenger Unlock Motor     RED / white     5 wire     pass kick or BCM behind glove box, white 16 pin plug (5), pin 6
Parking Lights (-)     BROWN / red     -     headlight sw or BCM behind glove box, blue 24 pin plug (2), pin 23
Parking Lights (+)     blue/black     +     passenger kick, harness to rear
Hazards     blue / YELLOW     -     hazard sw or BCM behind glove box, blue 24 pin plug (2), pin 7
Turn Signal (Left)     BLACK/ red     +     pass kick or BCM behind glove box, white 16 pin plug (5), pin 3
Turn Signal (Right)     RED / white     +     pass kick or BCM behind glove box, white 16 pin plug (5), pin 2
Headlight     RED / black     -     headlight sw or BCM behind glove box, blue 24 pin plug (2), pin 24
AutoLights     yellow (interrupt to turn off autolights)     -     headlight sw or BCM, white 24 pin plug (6), pin 1
Reverse Light     blue/white     +     pass kick or BCM behind glove box, gray 24 pin plug (1), pin 9
Left Front Door Trigger     WHITE/ blue     - N.C.     either kick or BCM behind glove box, white 24 pin plug (6), pin 4
Right Front Door Trigger     RED / yellow     - N.C.     passenger kick or BCM, wht 24 pin plug (6), pin 16
Left Rear Door Trigger     BLACK/ orange     - N.C.     passenger kick or BCM, wht 24 pin plug (6), pin 3
Right Rear Door Trigger     WHITE/ black     - N.C.     passenger kick or BCM, wht 24 pin plug (6), pin 6
Dome Supervision     yellow/black     -     pass kick or BCM behind glove box, white 16 pin plug (5), pin 15
Trunk/Hatch Pin     RED / black     -     pass kick or BCM behind glove box, white 24 pin plug (6), pin 15
Rear Glass Pin     N/A
Hood Pin     gray     - N.C.     BCM behind glove box, gray 24 pin plug (1), pin 17
Trunk/Hatch Release     purple / YELLOW (rear handle switch)     -     pass kick or BCM behind glove box, white 24 pin plug (6), pin 8
Trunk Release Motor     RED / green     5 wire     pass kick or BCM behind glove box, white 16 pin plug (5), pin 4
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     blue/orange (driver door key lock)     -     either kick or BCM behind glove box, white 24 pin plug (6), pin 2
Factory Alarm Disarm     lt. GREEN/ red (driver door key unlock)     -     either kick or BCM behind glove box, white 24 pin plug (6), pin 13
Disarm No Unlock     (transponder and ignition)
Trunk Alarm Shunt     N/A
Tachometer     BLACK/ white, BLACK / YELLOW, BLACK/ blue, or blk/org     ac     any fuel injector, white 2 pin plug, pin 1
Wait to Start     N/A
Neutral Safety     blue/orange (M/T)     -     PCM on driver side of engine, plug towards rear, pin 44
Clutch Pedal     BLACK/ orange     -     clutch switch, white 2 pin plug, pin 1
Fuel Pump     BLACK/ white     +     passenger kick, harness to rear
Rear Defroster     PURPLE / red     - latched     BCM behind glove box, gray 24 pin plug (1), pin 14
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     blue/black     + latched     LH seat warmer switch, black 6 pin plug, pin 6
Right Front Heated Seat     RED / green     + latched     RH seat warmer switch, white 6 pin plug, pin 6
Speed Sense     GREEN / WHITE (A/T)     ac     TCM next to underhood fuse box, gray 39 pin plug, pin 36
Brake Wire     RED / yellow     +     brake switch, white 4 pin plug, pin 4
Parking Brake     brown     -     pass kick or BCM behind glove box, blue 24 pin plug (2), pin 9
Horn Trigger     PURPLE / white     -     horn switch or BCM behind glove box, blue 24 pin plug (2), pin 11
Wipers     gray     -     wiper switch or BCM behind glove box, blue 18 pin plug (4), pin 14
Left Front Window (Up/Down)     RED / white - green     A     power window main switch, white 14 pin plug, pins 3 - 2
Right Front Window (Up/Down)     WHITE/ red - blue     A     driver kick, harness to rear
Left Rear Window (Up/Down)     white - yellow     A     driver kick, harness to rear
Right Rear Window (Up/Down)     red - BLACK/ red     A     driver kick, harness to rear
Sun Roof (Open/Close)     blue/black - GREEN / WHITE (funct with ign on only)     +     sunroof switch, white 6 pin plug, pins 5 - 4
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     blue/red     +     radio, white 24 pin plug, pin 14
Radio Ground     BLACK/ red     -     radio, white 24 pin plug, pin 24
Radio Ignition     RED / green     +     radio, white 24 pin plug, pin 22
Radio Illumination     lt GREEN/ red (parking lights), PURPLE / grn (dimmer)     +,-     radio, white 24 pin plug, pins 15, 16
Factory Amp Turn-on     N/A
Power Antenna +     radio, white 2 pin plug, pin 1
Left Front Speaker (+/-)     red - white     +,-     radio, white 24 pin plug, pins 1 - 2
Right Front Speaker (+/-)     gray - yellow     +,-     radio, white 24 pin plug, pins 3 - 4
Left Rear Speaker (+/-)     purple - pink     +,-     radio, white 24 pin plug, pins 10 - 11
Right Rear Speaker (+/-)     WHITE/ red - BLACK/ red     +,-     radio, white 24 pin plug, pins 12 - 13
Center Channel (+/-)     N/A
Subwoofer (+/-)     N/A
Aux. Audio Input Left (+/-)     RED / white - RED / blue     +,-     radio, white 16 pin plug, pins 14 - 5
Aux. Audio Input Right (+/-)     black - RED / blue     +,-     radio, white 16 pin plug, pins 6 - 5
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     black - white or green (bluetooth/satellite audio)     +,-     radio, white 16 pin plug, pins 3 - 11
RSE Audio Right (+/-)     red - white (bluetooth/satellite audio)     +,-     radio, white 16 pin plug, pins 2 - 11
Satellite Radio 12 Volts     blue/red     +     Sat Radio behind glove box, gry 16 pin plg, pin 16
Satellite Radio Ground     BLACK/ red     -     Sat Radio behind glove box, gray 16 pin plg, pin 1
Satellite Radio Ignition     RED / green     +     Sat Radio behind glove box, gray 16 pin plg, pin 8
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     black - white     +,-     Satellite Radio, gray 16 pin plug, pins 3 - 4
Satellite Audio Right (+/-)     red - white     +,-     Satellite Radio, gray 16 pin plug, pins 2 - 4
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     5.5 x 7.5 left front door
Left Front Tweeter     1.2 left front door
Right Front Speaker     5.5 x 7.5 right front door
Right Front Tweeter     1.2 right front door
Left Rear Speaker     5.5 x 7.5 left rear quarter panel
Left Rear Tweeter     N/A
Right Rear Speaker     5.5 x 7.5 right rear quarter panel
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     N/A
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner
Gary Sather
funkypc
Posted: January 08, 2015 at 2:42 PM / IP Logged
Thank you very much.
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
