remote start, 2012 kia sorento
doug1025
Posted: January 12, 2015 at 9:51 PM / IP Logged
hey guys I installed a remote start on a 2012 kia sorento with a pushbutton start,v6,auto trans.i used a prestige aps-57e and an flcan.it locks and unlocks the doors but will not crank.i do notice that when the doors are locked with the remote key fob the led on the antenna keeps blinking and the led on the flcan does not light up while trying to remote start. this is my 4th remote install and I am learning,any ideas?
doug1025
chev104275
Gold - Posts: 1,436
Posted: January 13, 2015 at 7:56 AM / IP Logged
I do mainly idatalink stuff but flash link is the same thing. What did you flash the module with ? Did you follow the install guide correctly ? Are you using the 3 diodes the guide calls for ?
tedmond
Gold - Posts: 4,610
Posted: January 13, 2015 at 8:54 AM / IP Logged
keep the door shut and locked then try to remote start. it will not crank with a door open. verify the 2 pts wires and ensure brake lights go on during start.
Ted
Compustar Expert
doug1025
Posted: January 13, 2015 at 10:01 PM / IP Logged
hey chev thanks for reply,i flashed the module from flashlogic site,i have done this before,i did install the diodes where they are suppose to go,i followed the wiring diagram and wired it exactly as shown,i will get vehicle back and recheck everything again.maybe I am overlooking something.
doug1025
doug1025
Posted: January 13, 2015 at 10:06 PM / IP Logged
hey ted I did lock the doors but did not check brake lights during starting attempt,can you explain this to me about the brake lights,thanks
doug1025
tedmond
Gold - Posts: 4,610
Posted: January 13, 2015 at 10:34 PM / IP Logged
to start the vehicle, you need to step on the brake and hold the start button. to trick this vehicle into starting, the bypass turns on a relay to energize the brake circuit temporarily. when remote starting make sure brake lights turn on for a few seconds. it will disengage right after starting.
Ted
Compustar Expert
shark mobile
Copper - Posts: 83
Posted: January 14, 2015 at 7:57 PM / IP Logged
Never used a prestige but I know with several other brand you have to program the RS for push-to-start...worth checking I think
Solder, tape, repeat!
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
