2004 Ford Expedition
barberjb
Posted: August 20, 2015 at 8:30 AM / IP Logged Link to Post Post Reply Quote barberjb
Have a 2004 Ford Expedition Eddie Bauer with the in-dash 6-cd changer without navigation. An old thread had reference to the wiring diagram (see https://www.the12volt.com/installbay/forum_posts.asp?tid=56609) but the images are no longer available. Can someone possibly repost that information? Thanks in advance.
Platinum - Posts: 13,725
Posted: August 20, 2015 at 8:46 AM / IP Logged Link to Post Post Reply Quote i am an idiot
barberjb
Posted: August 20, 2015 at 2:57 PM / IP Logged Link to Post Post Reply Quote barberjb
Thanks for the link the the harness. I'm hoping to get the pin diagram for the connections on the back of the OEM radio. I bought the car used, and I ripped out an aftermarket DVD player that was causing issues. It appears that the Expy came with factory DVD, but not sure. In any case, the aftermarket DVD player was routed through an FM transmitter and it's lousy, so I'm looking to wire a new one correctly into the radio. Maybe I just need a http://www.metraonline.com/part/70-5520AV?
Posted: August 20, 2015 at 8:20 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Yes.
barberjb
Posted: August 24, 2015 at 7:19 PM / IP Logged Link to Post Post Reply Quote barberjb
Ok, now that I've spent the money for the Metra part, this is not what I'm looking for. It's for connecting the factory DVD player to a new radio, not for wiring something to the existing factory 6-cd changer. I'm asking again for the wiring diagram for the factory radio if it's available. Thanks.
Posted: August 24, 2015 at 8:25 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Is there a plug behind your radio that will plug into the 5520AUX?
barberjb
Posted: August 24, 2015 at 8:44 PM / IP Logged Link to Post Post Reply Quote barberjb
Yes, there is a 16 pin connector that mates with the 5520AUX / 5520AV, but it's obviously the opposite sex. Using the 5520AV wiring pins as a guide, I could take apart the factory harness on the back of the radio and swap the wires for the RCA cables in, but I'm trying to double check the wiring diagram so I do things correctly.
barberjb
Posted: August 24, 2015 at 8:46 PM / IP Logged Link to Post Post Reply Quote barberjb
Posted: August 24, 2015 at 9:01 PM / IP Logged Link to Post Post Reply Quote i am an idiot
That will plug into the factory radio.
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
