2015 Ford Expedition EL Stereo Wiring Diagram
disinhouston
Posted: August 28, 2015 at 10:33 AM / IP Logged Link to Post Post Reply Quote disinhouston
I've recently purchased a JBL MS-8 "System Integration Digital Sound Processor" and have been searching for the stereo wiring diagram for my 2015 Ford Expedition EL with no luck.
The local stereo shop wants anywhere from $500 to $1000 just to install this unit that requires only pwr, rmt, gnd, high level in & hi level out connections... ridiculous! I have many years’ experience installing 12V products and am certain I can conquer this task but acquiring the factory amp locations and stereo wiring color codes are a must before I start tearing this vehicle apart.
Anyone have any suggestions?
Thanks in advance!
ds
mleaser
Member - Posts: 18
Posted: September 03, 2015 at 8:21 PM / IP Logged Link to Post Post Reply Quote mleaser
Radio 12V     gray/red or WHITE/ red     +     radio, 24 pin plug, pin 1
Radio Ground     BLACK/ blue     -     radio, 24 pin plug, pin 13
Radio Ignition     gray/blue (base radio); (CAN bus, non base radio)     +     radio, 24 pin plug, pin 2
Radio Illumination     blue/white (base radio)     + dimmer     radio, 24 pin plug, pin 3
Factory Amp Turn-on     PURPLE / red     +     radio, 24 pin plug, pin 7
Power Antenna     yellow/orange (except base radio)     +     radio, 24 pin plug, pin 2
Left Front Speaker (+/-)     white - WHITE/ brown     +,-     radio, 24 pin plug, pins 8 - 21 or 22 - 10
On models with amplifier, the speaker wires are white - WHITE/ brown (woofer); GREEN/ orange - gray/orange (tweeter) at the amplifier in left rear quarter panel, 16 pin plug, pins 2 - 10; 3 - 11.
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange     +,-     radio, 24 pin plug, pins 11 - 12 or 23 - 11
On models with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange (woofer); PURPLE / orange - yellow/orange (tweeter) at the amplifier in left rear quarter panel, 16 pin plug, pins 6 - 14; 7 - 15.
Left Rear Speaker (+/-)     WHITE/ green - BROWN / yellow     +,-     radio, 24 pin plug, pins 9 - 22 or 21 - 9
On models with amplifier, the speaker wires are WHITE/ green - BROWN / yellow (woofer); GREEN/ brown - PURPLE / brown (tweeter) at the amplifier in left rear quarter panel, 16 pin plug, pins 4 - 12; 5 - 13.
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, 24 pin plug, pins 10 - 23 or 24 - 12
On models with amplifier, the speaker wires are BROWN / white - BROWN / blue (woofer); GREEN/ brown - PURPLE / brown (tweeter) at the amplifier in left rear quarter panel, 16 pin plug, pins 8 - 16; 5 - 13.
Center Channel (+/-)     green - gray / YELLOW     +,-     amplifier in left rear quarter panel, 16 pin plug, pins 1 - 9
Subwoofer (+/-)     PURPLE / green - GREEN/ wht (1); GREEN/ pur - gray (2)     +,-     amplifier in left rear quarter panel, 16 pin plug, pins 1 - 9; 2 - 10
Aux. Audio Input Left (+/-)     blue - YELLOW /GREEN (without SYNC)     +,-     radio, 24 pin plug, pins 18 - 19
Aux. Audio Input Right (+/-)     blue/green - WHITE/ green (without SYNC)     +,-     radio, 24 pin plug, pins 16 - 17
RSE Video (+/-)     WHITE/ green - BROWN / purple (rearview camera video)     +,-     front control/display mod, 12 pin plug, pins 6-12
On models with SYNC 2, the rearview camera video wires are WHITE/ green - BROWN / purple at the SYNC Module/display, 54 pin plug, pins 14 - 15.
RSE Audio Left (+/-)     blue - gray/orange (SYNC audio)     +,-     radio, 26 pin plug, pins 12 - 25
RSE Audio Right (+/-)     PURPLE / green - BROWN / white (SYNC audio)     +,-     radio, 26 pin plug, pins 13 - 26
disinhouston
Posted: September 05, 2015 at 9:16 AM / IP Logged Link to Post Post Reply Quote disinhouston
Thanks a lot for this!!!
ds
disinhouston
Posted: July 10, 2016 at 12:29 PM / IP Logged Link to Post Post Reply Quote disinhouston
Do have the wiring color codes for factory amp input plug? I need to tie these input wires into the high level input on my JBL MS-8. Your output color codes were spot on!
Thanks.
ds
disinhouston
Posted: July 10, 2016 at 12:30 PM / IP Logged Link to Post Post Reply Quote disinhouston
Thanks.
ds
Platinum - Posts: 13,725
Posted: July 10, 2016 at 1:01 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Chances are the level coming out of the radio will not be enough to drive your amplifier. You will probably need to get signal from the output.
