Viper 4806v on toyota camry with key override
gpslitt
Member - Posts: 8
Posted: December 03, 2015 at 11:12 AM / IP Logged Link to Post Post Reply Quote gpslitt
it didnt start,
parking light flashes 7 times, as per guide, its is manual mode,
need programming to get to automatic,
but didnt going to programming mode as given on guide,
any suggesstions
pls advice
regds...Litt
Regds..Litt
Posted: December 03, 2015 at 11:28 AM / IP Logged Link to Post Post Reply Quote howie ll
Make sure green door trigger on H2 aux plug goes to ground when a door is open.
Make sure pink on heavy duty harness goes to 12V+ on ignition.
Test from the plug to your grounding point.
Make sure the antenna is correctly plugged in at both ends.
Carefully read the programming instructions.
Open driver door, ign on then off, hold button on control centre, 1, then 2 then three chirps release, press button once, press remote lock button, should hear 2 chirps.
That's off the top of my head so double check.
gpslitt
Member - Posts: 8
Posted: December 03, 2015 at 7:23 PM / IP Logged Link to Post Post Reply Quote gpslitt
thnx howie it worked, will be posting all findings tomorrow
thnx again
Regds..Litt
