Nissan Rogue 2012 remote starter install
prince504
Copper - Posts: 108
Posted: December 25, 2015 at 9:35 AM / IP Logged Link to Post Post Reply Quote prince504
Merry Christmas everyone!!
I am currently in the process of trying to install a Fortin Evo-All bypass & Prestige remote alarm in a 2012 Nissan Rogue (base model Non-PushToStart). I have gotten wiring diagrams from all over the web & am having a hard time finding the Factory Disarm & Arm wires.
I have confirmed the car has a factory alarm by locking my doors w/ the window down, waiting a few minuets & opening the door & the alarm rang.
I have a multimeter and am testing to find a red 12V wire that changes to ground when the door is locked & a blue 12V wire that does the same when the door is unlocked.
Please help...
smokeman1
Platinum - Posts: 1,589
Posted: December 25, 2015 at 11:28 AM / IP Logged Link to Post Post Reply Quote smokeman1
Listed in Directed DBALL2 diagram:
White, 40 pin connector at BCM
ARM, Pin 8, Red
Disarm, Pin 7, Blue....
Bulldog Security site states: TEST this wire while Turning the KEY in the Drivers Door.
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
prince504
Copper - Posts: 108
Posted: December 26, 2015 at 7:32 AM / IP Logged Link to Post Post Reply Quote prince504
Thnx for the reply @smokeman1. I appreciate it.
Prior to your response, I decided to undo the glove box compartment to find this "BCM" the wire charts had said it "might" be in and found the wires! The only strange thing is that ALL pictures online pointed to the 40-pin connector being at the driver side kick panel area. But in all fairness, they did also say it "might" behind the glove box.
Also, when I used my DMM to test the wires at the 40 pin connector, although the arm showed a 12V reading & the disarmed wire showed a 7V reading. My Nissan Rogue requires a double pulse, is that why the disarm is low?
Secondly, when I used the remote to arm & disarm the vehicle, the multimeter didn't go to 0 (or close to it). The number dropped about 1V & went back to normal reading. Is this because I didn't do it via my door lock?
Also @smokeman1 since my Nissan Rogue already has a factory alarm, I don't need to wire up the siren that came w/ my prestige right?
Thnx in advance
