2014 Jeep Patriot wiring
wolv2401
Member - Posts: 9
Posted: December 26, 2015 at 3:15 PM / IP Logged Link to Post Post Reply Quote wolv2401
Does anyone have remote start / alarm wiring for a 2014 Jeep Patriot?
prdjr165
Copper - Posts: 293
Posted: December 26, 2015 at 5:16 PM / IP Logged Link to Post Post Reply Quote prdjr165
12volts
      red
      battery or underhood fuse box
Starter      yellow/gray (for starter kill only)      +      driver fender, black 14 pin plug, pin 8
Second Starter      PURPLE / brown (use interface mod or Tech Doc 1084)      - 180 ohms      ignition switch, black 5 pin plug, pin 2
Ignition      pink/white      +      ignition switch, black 5 pin plug, pin 3
Second Ignition      N/A
Third Ignition      N/A
Accessory      same as second starter      - 610 ohms
Second Accessory      N/A
Keysense      same as second starter      -8.2K ohms
Power Lock      lt. GREEN/ dk. green      - 330 ohms      left of steering column, black 43 pin plug, pin 30
Power Unlock      same as power lock      - 100 ohms
Lock Motor      tan/dk. blue      5 wire      left of steering column, black 43 pin plug, pin 11
Unlock Motor      tan/dk. green      5 wire      left of steering column, black 43 pin plug, pin 39
Parking Lights+      WHITE/ purple      +      driver kick, harness to rear
Parking Lights-      (LIN bus)
Hazards      (LIN bus)
Turn Signal(L)      WHITE/ red (F); dk. GREEN/ red (R)      +      turn signal light (F); driver kick, harness to rear (R)
Turn Signal(R)      WHITE/ tan (F); WHITE/ yellow (R)      +      turn signal light (F); driver kick, harness to rear (R)
Reverse Light      WHITE/ lt. green      +      driver kick, harness to rear
Door Trigger      PURPLE / dk. blue      -      left of steering column, black 43 pin plug, pin 17
Dome Supervision      yellow/white      +      driver front pillar, gray 20 pin plug, pin 12
Trunk/Hatch Pin      PURPLE / orange      -      left of steering column, black 43 pin plug, pin 1
Hood Pin      PURPLE / lt. blue      -      hood switch, black 2 pin plug, pin 1
Trunk/Hatch Release      locks/unlocks along with doors
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      see disarm no unlock
Disarm No Unlock      Sentry Key, ignition, and keysense
Tachometer      yellow/brn, brn/dk. blue, brn/lt. blue, or brn/tan      ac      any fuel injector, black 2 pin plug, pin 1
Wait to start      N/A
Brake Wire      dk. GREEN / WHITE      +      left of steering column, black 43 pin plug, pin 27
Parking Brake      dk. GREEN/ lt. blue      -      parking brake switch
Horn Trigger      gray / YELLOW (1), gray/lt. blue (2)      5 wire      horns or underhood fuse box, green 22 pin plug, pins 9 and 8
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
MAKE : JEEP | MODEL : PATRIOT | YEAR : 2014
* The logo is registered trade mark of Jeep Corporate.
Platinum - Posts: 7,828
Posted: December 26, 2015 at 6:22 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is a link to a R/S Pictorial on your Jeep :  https://www.the12volt.com/installbay/forum_posts.asp?tid=130393
wolv2401
Member - Posts: 9
Posted: December 26, 2015 at 6:23 PM / IP Logged Link to Post Post Reply Quote wolv2401
Awesome thank you so much. I used to have access to direct techs at my last job but not anymore haha. Appreciate it!
wolv2401
Member - Posts: 9
Posted: February 26, 2016 at 9:30 AM / IP Logged Link to Post Post Reply Quote wolv2401
Now that I have that project completed, any tips on a remote turn on wire for an aftermarket amp? I already swapped out all interior speakers with some higher end Kicker 6x9s. I have a Kicker 4 channel amp from my last vehicle, but just wasnt positive which wire to go to for the amp's remote turn on.
Any tips would again be appreciated. Thanks!
