Switchback using stock 2013 Mustang Headlights
vartech
Posted: December 27, 2015 at 4:23 PM / IP Logged Link to Post Post Reply Quote vartech
I have a set of 2013 mustang headlights. I am trying to use the drl and have the turn signal turn of the drl when active. I am using a morimoto switchback driver but I believe that driver cuts the ground not power. The issue is the headlight assembly uses a common ground for drl and highbeam and when the turn signal is on the drl turns off and the high beam does not work. I need help coming up with a solution.
vartech
Posted: January 15, 2016 at 8:34 PM / IP Logged Link to Post Post Reply Quote vartech
found solution use diodedynamics ds1
