2006 Chevy Malibu Maxx, Avital 5303, DBALL2
killerpoptart
Posted: March 24, 2016 at 9:53 AM / IP Logged Link to Post Post Reply Quote killerpoptart
Does anyone happen to have the direct techs wiring information for the Avital 5303 and DBALL2, for a 2006 Chevy Malibu Maxx. I mostly just need the Avital wiring but both would be greatly appreciated, Thanks.
smokeman1
Platinum - Posts: 1,589
Posted: March 24, 2016 at 9:27 PM / IP Logged Link to Post Post Reply Quote smokeman1
https://www.directechs.com/VehicleCompatibility.aspx?p=-1&year=2006&make=Chevrolet&model=Malibu%20MAXX&ps=1&s=0&c=0
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
killerpoptart
Posted: March 25, 2016 at 4:59 AM / IP Logged Link to Post Post Reply Quote killerpoptart
Thanks for the information, but I had found most of those connects. Here is what I have and don't have.
https://goo.gl/zNVYri - Excel doc
Vehicle Information: 2006 Chevy Malibu Maxx
Alarm / Remote Start Unit: Avital 5303
Bypass Module: DBALL2
Alarm / Remote Start / Bypass Unit   Vehicle
Connection     Color     Description     Color     Polarity     Location:
Main Harness (H1), 12-pin connector
H1/1      RED / WHITE      (-) 200mA AUX TRUNK RELEASE OUTPUT     BROWN / WHITE     (-)     BCM, C1, 72PIN GRAY PLUG, PIN 71
H1/2      RED      (+) CONSTANT POWER INPUT     Red     (+)     BCM, C3 RED 41PIN PLUG, PIN D1
H1/3      BROWN      (+) SIREN OUTPUT   Goes to positive on siren
H1/4      NOT USED     NOT USED     not used     not used     not used
H1/5      BLACK      (-) CHASSIS GROUND INPUT (-)     ground
H1/6      VIOLET     (+) DOOR TRIGGER INPUT, ZONE 3
H1/7      BLUE      (-) INSTANT TRIGGER INPUT, ZONE 1
H1/8      GREEN     (-) DOOR TRIGGER INPUT, ZONE 3
H1/9      BLACK/ WHITE     (-) 200mA DOMELIGHT SUPERVISION OUTPUT   BCM, C3, 41PIN
H1/10      WHITE/ BLUE      (-) REMOTE START ACTIVATION INPUT
H1/11      WHITE      (+)/(-) SELECTABLE LIGHT FLASH OUTPUT
H1/12      ORANGE      (-) 500mA GROUND WHEN ARMED OUTPUT
H2 Harness, 6-pin connector
H2/1      BLUE      (-) 200mA SECOND UNLOCK OUTPUT
H2/2      WHITE/ BLACK     (-) 200mA AUX 3 OUTPUT   Optional Aux option
H2/3      VIOLET/BLACK     (-) 200mA AUX 2 OUTPUT   Optional Aux option
H2/4      GREEN / WHITE      (-) 200mA FACTORY ALARM REARM OUTPUT
H2/5      GRAY/BLACK      (-) WAIT-TO-START INPUT   not needed
H2/6      LIGHT GREEN/ BLACK      (-) 200mA FACTORY ALARM DISARM OUTPUT
H3 Harness Remote Start, 5-pin connector
H3/1      BLACK/ WHITE      (-) NEUTRAL SAFETY SWITCH INPUT   Provided switch with other end to ground when park or neutral ?
H3/2      VIOLET/WHITE      TACHOMETER INPUT WIRE   negetive side of ignition coil / ANY FUELINJECTOR
H3/3      BROWN      (+) BRAKE SHUTDOWN INPUT WIRE   BCM, C1 72PIN GRAY PLUG, PIN 42,
H3/4     GRAY      (-) HOOD PIN SWITCH INPUT, ZONE 6   Hood pin switch
H3/5      BLUE/WHITE      (-) 200 mA 2ND STATUS/REAR DEFOGGER - Latched Pulsed
H4 AUX 4/Horn, 2-pin connector
H4/1      ORANGE / BLACK     (-) 200mA AUX 4 OUTPUT   Optional aux option
H4/2      BROWN      (-) 200 mA HORN OUTPUT
Door Lock, 3-pin connector
1     BLUE      (-) UNLOCK OUTPUT
2     NOT USED     NOT USED     NO USED     NOT USED     NOT USED
3     GREEN     (-) LOCK OUTPUT
Heavy gauge relay satellite
H/1      PURPLE      STARTER OUTPUT TO STARTER (STARTER SIDE)   ignition switch starter side of cut starter wire
H/2      GREEN      STARTER INPUT FROM IGNITION SWITCH (KEY SIDE)   ignition switch key side of cut starter wire
H/3      RED      (+) 30A HIGH CURRENT 12V INPUT     red red 12v at ignition switch
H/4      ORANGE      OUTPUT TO ACCESSORY CIRCUIT     brown     (+)     Pin 4 ignition switch
H/5      RED      (+) (30A) HIGH CURRENT 12V INPUT
H/6      PINK      OUTPUT TO PRIMARY IGNITION CIRCUIT     Pink or Yellow     (+)     Pin 3 ingnition switch
H/7      RED / WHITE      (+) (30A) HIGH CURRENT 12V INPUT   if no 2nd ignition/accessory, then this wire is not needed
H/8      PINK/WHITE      OUTPUT TO SECOND IGNITION/ACCESSORY CIRCUIT
Relay satellite 4-pin connector
1     BLUE      (-) 200mA STATUS OUTPUT
2     ORANGE      (-) 200mA ACCESSORY RELAY TURN ON
3     PURPLE      (-) 200mA STARTER RELAY TURN ON
4     PINK      (-) 200mA IGNITION RELAY TURN ON
Remote Start ribbon harness
connects satellite relay to main unit
DBALL2
Blue Harness
1     Light Green     Single Wire CAN     Dark Green pin 1 of OBD2 from pin side
10     ORANGE / Red     Immo. Constant (Car Side)     RED / White Black Connector located at the ignition switch
11     Yellow/Red     Immo. Constant (Conn. Side)     RED / White Black Connector located at the ignition switch
13     not needed with D2D -     -     -
14     not needed with D2D -     -     -
Red Harness
1     BLACK/ White     Drive door trigger
7     Gray/Black     (+) Accessory Output     Brown     (+)      Accessory, pin 4
10     Yellow/Black     Keyless Data     Tan/White or Light Green BCM connector C2 pin 12
Black Harness
Not needed with D2D cable
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
