2007 Chevy Cobalt OE cruise control
jgerard81
Posted: April 15, 2016 at 8:27 AM / IP Logged Link to Post Post Reply Quote jgerard81
I am installing the OE cruise control switch in my 2007 Chevy Cobalt LS. Currently, I have all the wires connected from the clock spring to the BCM. The only issue I have is not being able to find any information about the wire harness that connects from the cruise control switch, to the other end of the clock spring. If someone could share a diagram of the harness that connects from the 5 pin connector on th OE cruise control swith to the 11 pin connector on the clock spring, I would truly appreciate it.
jgerard81
Posted: April 15, 2016 at 6:30 PM / IP Logged Link to Post Post Reply Quote jgerard81
I think I was able to find half the information I needed.
Pin 4 (Pink) of the cc switch to pin C of clock spring (SIR coil)
Pin 5 (Gray) of the cc switch to pin D of clock spring
Pin 7 (Blk/Wht) of the cc switch to pin K of clock spring
I am still unable to find anything related to which wires are for the Driver Information Controls. Also, if the pinout above is incorrect, please feel free to correct.
Thank you for taking the time to help.
jgerard81
Posted: April 17, 2016 at 9:29 PM / IP Logged Link to Post Post Reply Quote jgerard81
I ended up just using the wire harness that came factory on my 2007 Cobalt LS. I added in a wire between pin 4 of the cc connector and pin C of the clock spring connector, and another wire between pin 5 of the cc connector and pin D of the clock spring connector. The other 3 wires just stayed where they were.
The hardest part of adding the OE cruise control to this car was convincing a GM dealership to enable it in the cars computer. Once they finally did it, it works great.
