LED panels
webpager
Member - Posts: 24
Posted: April 22, 2016 at 12:57 AM / IP Logged Link to Post Post Reply Quote webpager
Hey folks,
I have almost no experience with LEDs, so I want to throw this out to be sure I'm thinking correctly.
I may be building a project with a large number of LED panels. They are pre-built, 12V pieces. (24 SMD 5630s each). You can see what I'm going to use here: http://www./itm/10X-Red-Car-24-SMD-5630-LED-panel-Light-Dome-Bulb-T10-Festoon-Spring-12V-/310862502050?hash=item4860d958a2:g:ohwAAOxyDEVScSTQ
Since these are already mounted and wired to use 12V, I can simply wire the boards in parallel. I'll be using a PWM dimmer, and groups of lights will be on separate circuits.
Appreciate your time and expertise.
MCSteven
webpager
Member - Posts: 24
Posted: April 22, 2016 at 12:59 AM / IP Logged Link to Post Post Reply Quote webpager
Sorry - I didn't realize that we can't post eBay links. If you search that site for "Red Car 24 SMD 5630 LED panel" it should give you the correct results.
