If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Did you install the Starter Killer relay as in the diagram and to which wire?
For Anti-robbery to work the Ignition wire needs to be cut and run to 87a (keyside) and 30 (vehicle side) of relay.
If you installed the Starter killer relay on the starter wire then you have 2 choices .
1.) Move it to the ignition wire to make the Anti-robbery work.
2.) Leave it on the Starter wire and add another relay to Ignition wire using the same orange (-) wire to ground both relays.
If the starter still grinds with the relay on the starter wire When doing take over with key then you will need to isolate the Acc. "Need to test this with key does starter engage with key while remote started?"
