Accessory wire hookup 2006 durango
trembuzz
Member - Posts: 30
Posted: December 13, 2016 at 10:04 AM / IP Logged Link to Post Post Reply Quote trembuzz
A previous owner had a python remote start installed but only the rear fan and not the front fan comes on. I'm guessing that the accessory wires got mixed up during the install. Should acc. 1, acc. 2 or both be hooked up to enable the front fan to engage
trembuzz
Member - Posts: 30
Posted: December 13, 2016 at 11:54 AM / IP Logged Link to Post Post Reply Quote trembuzz
Doing some follow-up research I found that the purple (-) wire has to have a relay hooked up. I'm guessing the original installer wasn't aware of this. Does someone know the proper way to hook a relay up for this wire?
Thanks in advance,
trembuzz
Platinum - Posts: 13,726
Posted: December 13, 2016 at 3:06 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Ground to terminals 30 and 85. Remote start unit's positive accessory output wire to terminal 86. 87 will be the negative output to provide - to the wire of the vehicle.
trembuzz
Member - Posts: 30
Posted: December 14, 2016 at 8:50 AM / IP Logged Link to Post Post Reply Quote trembuzz
Thanks a bunch. Now I just have to get under the dash and figure out which model is installed. Should I be concerned about your username? lol
trembuzzAccessory wire hookup 2006 durango - Last Post -- posted image.
Posted: December 14, 2016 at 8:05 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Be concerned. Be very concerned.
trembuzz
Member - Posts: 30
Posted: December 14, 2016 at 10:14 PM / IP Logged Link to Post Post Reply Quote trembuzz
Hmmm..... Your relay install info was spot on. But now this is very disconcerting. Accessory wire hookup 2006 durango - Last Post -- posted image.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
